Ezlo Protect v1.4
Sara
Sara
  • Updated
New Features
  • Fixed Siren Timeout default value
  • Default Entry Delays
  • Door Lock pin code assignment from the resident app
  • Sensor Groups and predefined entry delays
  • Restrictions for pairing security Z-Wave and Zigbee devices for residents
  • UI changes for Smart Home-only plans
  • Bypass prevention for life safety devices
  • Help and diagnostics info made available on mobile apps
  • Arming with sensors bypass v2
  • In-app prompt for enabling OS-level notifications when disabled
  • Distinguishable Exit/Entry and keystroke beeps
  • Various UI improvements and changes
  • Configurable on-open and on-close chime settings for security sensors
  • User settings access restricted with Master Pin Code
  • Device addition restricted while system is armed
  • Initial password creation flow applied to users created by admin users
  • Information screen for notification-only users
  • Generic 345 MHz sensors categories added for ease of installation
  • Enabled 2-way audio from Web Dashboard
Cloud v1.112
  • Improved Pin Codes Management
  • Performance improvements for storage services
  • Performance improvements for multiple internal services
Partner Portal v2.3.8
  • Customer List Export feature added under “Reports” menu
iOS Installer App v1.18
  • Generic 345 MHz sensor categories added for ease of installation
  • Default Entry Delays and Sensor Groups
  • Help and diagnostics info made available on Installer app
iOS Resident App v1.15
  • Improved Sensor Bypass Arming
  • Updated and improved user creation flow
  • Implemented self-monitored Smart Home Plan
  • Implemented Informative screen to inform notification-only users of their capabilities
  • Implemented redirection to OS notification permissions if these are not allowed
  • Implemented Pin Codes Management via the Resident app
  • Restriction implemented to prevent devices from being paired while the system is armed
  • Restriction implemented to prevent residents from self-pairing security class devices
  • Fixes for Cellular Backup status
Android Installer App v1.122.1.61
Android Resident App v1.122.1.59
Touchscreen Dynamic Dashboard v2.1.43
  • Added visual marker when entering the disarm code on the Touchscreen Panel
  • Added Home button
  • Chime settings are enabled by default only when sensors are opened
  • Changed keypad click sound
  • Added restriction to prevent bypassing the life-safety sensors
  • Improved multi-language translations
  • Fixed authentication token for case sensitive usernames
  • Fixed condition preventing the device state updates from being updated without a dashboard refresh
  • Fixed condition preventing the snapshot camera preview from being loaded
  • Fixes related to the weather forecast values
  • Fixed condition showing an incorrect exit delay time
  • General UI fixes and improvements
  • Fixed condition allowing the video sounds to play in background
  • Added pagination capability to the snapshots list
  • Fixed condition preventing the thumbnails of camera recordings to be displayed
Resident Portal v2.0.1
  • Updated and improved password reset flow
  • Installer users are now correctly redirected to the appropriate mobile app
  • General functionality fixes and improvements
  • TX-ID is now displayed for the 2GIG devices
  • Fixed issue preventing correct plugin updates
  • Fixed condition causing Media Storage page to crash
  • Fixes related to device groups
Firmware v2.0.44.2279.11 (prod-155)
  • Device integration, fixes, and improvements
  • ZWave communication improved reliability
  • System fixes and improvements
  • Meshbot group operations
  • Meshbots fixes and improvements
  • Video streaming improvements
Was this article helpful?
0 out of 0 found this helpful
Comments
0 comments
