New Features
- Sensor Walk Test
- Local camera streaming
- 2GIG Panic Button integration
- New Help section on the Touchscreen Panel
Cloud v1.112.34
- Fixed issue where register command was taking too long
- Added pagination for partner installation status
- Fixed crashloop issue for partner installation status
- Resolved error return for partner installation status
- Addressed frequent service crashes
- Fixed sync issue for installation status in the database
- Added metrics for multiple services
- Fixed issue with cassandra-migrations service not applying all migrations
- Added account_type to legacy search output
- Switched legacy search to cassandra wrapper
- Added filter for partner group and partner group in output
- Fixed issue with legacy-search returning deleted plans
- Fixed account_type and group_uuid not printed as expected
- Added field prunning_by_age in Storage Buckets 1
- Created service protect-controller-signals
- Created service protect-cmsnd-signalling
- Created service protect-rapid-response-signaling
- Fixed unexpected service error with controller-signals service
- Resolved undefined Cmsnd account issue
- Updated service CMSND v.7 - Protect Location Resync Manager v.2
- Updated table Protect Controller Item Status
- Updated protect-signals-cmsnd service
- Updated DB schema
- Applied DB migrations for protect tables
- Resolved CrashLoopBackOff issue
- Fixed issue where service wasn't adding information to DB for CMSND users
- Fixed issue where service didn't receive message after sending event for cmsn users
- Addressed frequent service crashes and restarts
- Fixed issue where RR system didn't get events from silent SOS button
- Resolved issue with event not being received by cmsn system
- Corrected environment variable
- Implemented Silent alarms
- Updated Protect Controller Panic
- Fixed issue with protect-sender self-heal not working
- Fixed issue where message was not sent due to undefined receiverNumber
- Resolved issue with NMA failing to start due to logClientStatus error
- Improved performance of service storing user tokens
- Fixed issue where broadcasts were not handled due to missing item_id
- Fixed error with unsupported event type in protect-data-processor
- Corrected code E601 for Walk test start/stop and physical panic button (police)
- Fixed issue where the service couldn't process the code for walk test and panic button
- Fixed issue with Walk test finish event type not supported in protect-data-processor
Partner Portal v2.4.2
- Show IP and network information in system info section
- A warning regarding email validation was shown on the customer info section
- Issues are fixed on the report page
- Filter out 345 devices on devices section from partner portal
Dashboard v2.1.59
- Updated font size settings will now be reflected on the Cameras page
- Fixed an issue where the exit delay timer on the touchscreen was not syncing with the iOS app
- 2GIG Panic Button is now fully supported
- As a resident, you will now receive notifications if the system is in Controller Test mode
- The water valve will no longer be incorrectly labeled as an outlet
- Humidity and pressure units are now displayed in the weather forecast
- The help button in settings now correctly navigates to the native help screen
- Fixed an issue where a bypassed sensor after arming the system was still triggering an alarm
- Corrected condition that was causing the life safety sensor (leak) to incorrectly trigger an alarm during a Walk Test
- The Arm (Away) option is now correctly labeled
- Security sensors that are not bypassed will now trigger the alarm when the system is armed
Resident Portal v2.4.1
- Added default icons for the "Cloud Services" node type
- Added the option to download JSON templates for IP devices
- Fixed issue preventing the arming of Centralite door and motion sensors
- Corrected issue where the selection of the "not" operator was canceled after selecting or changing a node
- Implemented the NOT operator for the Expression node
- Implemented the NOT operator for the Device Group node
- Fixed errors related to Local Meshbot triggers due to incorrect data
- Fixed errors on the customization page
- Fixed errors on the Device Associations page
- Fixed errors on the variables page
- Fixed warnings on the My Account page
- Fixed errors on the Cloud Services page
- Fixed errors on the IP Devices page
- Fixed error on the Addressable LED page.
- SOS devices not displayed on the Devices page anymore
- Implemented feature to prevent Partner/Installer users from logging into the resident portal
- Fixed issue with Smart Dry Contact Switch 7 making parameter configuration impossible
- Enabled the "XOR" operator for ezlopi devices, depending on the firmware version
iOS
Ezlo Protect iOS Resident App v1.21(7)
New Features
- Local streaming for cameras - Improved camera streaming experience over the local network
Fixes & Improvements
- Multiple timeline UI updates and improvements
- Fixed condition causing timeline/history to not be updated unless you exit and re-enter the screen
- Fixed issue about the Share function for the recordings
- Fixed minor issue when the user avatar was not loading
Ezlo Protect iOS Installer App v1.18(12)
New Features
- Sensor Walk Test - now it's a lot easier to test and confirm the sensors are operating correctly
- Pin Codes V2 - Improved Pin Codes Management
- Addressed condition when no chime could be heard on the Dashboard
- Re-added "Long Extended Delay" option in the configuration menu
- Corrected behavior for sensor arm state be independent between Arm/Disarm modes
Android
Ezlo Protect Android Resident App v1.126.1.44
New Features
- New Help section on the touchscreen panel
- Sensor Walk Test - now it's a lot easier to test and confirm the sensors are operating correctly. You can access this feature by going to More > Settings > Controller Tests
- Fixed condition preventing the app from loading properly in landscape orientation
- Corrected the overlay sliders on the touchscreen panel to properly match the behavior of the physical buttons for sound and brightness
- Corrected rare condition showing incorrect CMS service status
Ezlo Protect Android Installer App v1.126.1.43
New Features
Firmware v2.0.58.2722.6 (prod-173)
Sensor Walk Test
- Modified security behavior for the System Sensor Test
- Improved the System Sensor Test to emit progress UI broadcasts
- Enhanced the System Sensor Test with hub.modes.get v3 to indicate when the system test is in progress
- Extended the duration of the Walk Test in the System Sensor Test
- Added a function to stop the Walk Test in the System Sensor Test
- Corrected condition: The manual communication test error message now displays correctly if the test fails, and the correct cloud signal is called
- Changed the manual communication test call to be done in an asynchronous way
- Corrected condition: Comm Test progress broadcasts are now only emitted when a comm test is started
- Added manual communication test for mobile interfaces
Networking
- Added system test events for Sensor Walk TestCorrected condition that was causing the hub to fail to connect to the cloud via LAN
- Added missing parameters to the hub.network.get required for Wifi connectivity
- Corrected condition: The wlan0 route no longer overrides the eth0 route
- Corrected condition where Wi-Fi scanning was not working
- Corrected condition: After a reset, the BSSID/channel scanner would keep scanning for networks in a loop
- Prevented the WiFi access point from blocking the client when running on a different frequency
- Corrected condition where interface monitoring was getting stuck
- Improved interface monitoring with external URLs and access point setup
- Added logging to the network manager to monitor its logic
- The WiFi scanner now uses the default WiFi interface
- Fixed the issue where the WiFi driver was failing to initialize due to a BCDC problem
Security & SOS Buttons
Updated default values for entry delay
- Instant = 0 sec
- Normal = 30 sec
- Extended = 60 sec
- Long Extended = 120 sec
- Excluded fire sensors from the Swinger Shutdown feature as fire sensors must never be bypassed
- Improved SOS button functionality
- Fixed the issue where the instant (0s) setting did not apply to SOS devices
- Corrected condition: After backup restoration, the plugin no longer shows more devices than allowed
- Corrected condition: All protect devices and items are now created as expected
- Fixed the issue where the ProtectService parameter was missing in the hub.item.updated broadcast
- Marked SOS button items as hidden in the plugin
- Improved hub features events and status get method
- Enhanced house modes to reflect silent alarms
- Added SOS button devices to the house modes protect.buttons collection
- Added protect SOS buttons device collection and events to house modes
- Created a device group for protect buttons, including devices, items, and instant entry delay
Logging
- Researched and resolved gaps in the log rotation mechanism
- Corrected condition: Logs are now rotated daily, resolving a logcmd deadlock issue
- Corrected condition where hub.log.send was only collecting logs from RAM, not from the pending folder
- Corrected condition: The UID log now prints command IDs at the INFO level and generates IDs for cloud commands
- Added logread and IP monitor tracking as part of the firmware
- Increased verbosity in the ha-mqtt_gateway logging
Firmware Metrics
- Fixed an issue causing the metrics service to crash repeatedly
- The external services tracker now monitors service status by process name instead of PID
- Added report statistics for custom services: ha-webrtcd, ha-mqttwebrtcd, ha-oracode, ha-mediamtx
New integrations
- Added support for the Kaadas KA200 Keypad Deadbolt
- Added support for the Zigbee Occupancy Sensing cluster (0x0406)
- Added support for the 2GIG-RTPR1-345 repeater
- Added support for the Sonoff SNZB-06P light sensor
- Added support for the Sonoff SNZB-06P presence sensor
General Updates & Fixes
- Added deadlock detection in the camera addon
- Added mqttwebrtc to the WebRTC control group
- Improved the backups planner to include persistent storage
- Added SSH tunnel health checks and status information
- Added metrics for current connection uptime, cumulative uptime, cumulative downtime, and number of reconnects
- Integrated WebRtc v2 with MediaMtx and CI and HubPlatformBundle
- Added control scripts for WebRtc v2 MediaMtx
- Added a recovery mechanism for services that are getting stuck
- Added a recovery mechanism for uninterruptible processes in the WiFi driver
- Corrected condition: Panic button notifications will now appear in Disarmed mode as well
- Added "protect true" to all broadcasts mapped to CMS signals
- Attached the 2GIG panic button to the "police" protect service
- Corrected condition that caused a preview upload error due to an incorrect payload format
- Fixed the core.modify_item function to prevent it from corrupting the item list
- Improved Z-Wave multicast requests by ignoring unreachable nodes and sending them as singlecast with a delay
- Added the ability to set item values for a list of items from an anonymous plugin
- Added support for collecting and sending Zigbee network structure data to the UI
- Fixed the issue where thermostat controls were unavailable for the Secure SRT321 model
- Fixed the issue where ha-luad crashed if core.send_ui_broadcasts was called with wrong parametersFixed the detection of temperature endpoints for the MCO Home Multi Relay MR8-ZW
- Corrected condition where pincode restrictions were not working on the Kwikset 916
- Fixed the issue with missing or filtered out znetNodeCmdNotification in Z-Wave
Comments
0 comments
