Ezlo Help Center
Ezlo Protect Touchscreen Panel
June 18, 2024 - Touchscreen Panel Dashboard - Version 1.127.2
  • Passed state is now visible during Sensor Test (Walk Test).
  • Fixed condition preventing Siren alert when security sensor triggered on the Touchscreen Panel.
  • EXTEND button is now displayed correctly before Walk Test completion and not after the test was finished.
  • Pin code dialog no longer appears twice in a row on the Touchscreen Panel.
  • Snapshots are now updating as expected on the Touchscreen Panel.
  • Sound sensor values are displayed in the correct format on the Touchscreen Panel.
  • Security sensors are now visible on Home screen on the Touchscreen Panel.
  • Fixed condition causing inability to re-arm system: re-arming is now possible immediately after disarming in Live mode on Native Dashboard.
  • Native Dashboard no longer crashes when accessing Cameras tab with no configured cameras.
  • Sensor Test now allows testing security devices without creating an alarm event or sending CMS signal.
  • Walk test can now be stopped after app restart.
  • App no longer crashes when canceling Walk Test.
  • Camera previews are now loading correctly on the Touchscreen Panel.
  • Motion sensor 'Passed' state is now visible during Sensor Test (Walk Test).
  • Extended timer time is now displayed correctly in the app.
  • Water valve is now correctly categorized on the Touchscreen Panel.
  • Arm/Disarm system sync problem resolved when canceling alarm using Pin Code.
  • Fixed condition preventing Siren alert when alarm is tripped by entering wrong pin code on Touchscreen Panel.
  • Fixed Live stream issue in Devices/Cameras menu.
  • Hubs are now synced correctly with the app on Touchscreen Panel.
  • Alarm no longer sounds during entry delay.
  • Error message no longer displayed after deactivating incorrect pincode alarm.
June 12, 2024 - Touchscreen Panel Dashboard - Version 1.127.1.567
  • Corrected light switches icons for seamless user experience.
  • Fixed pin code dialog to appear once, eliminating duplicates.
  • Corrected 'No Tempering Cover' status for door window sensors after pairing.
  • Resolved auto return to home screen issue.
  • Added heat sensor display in Devices menu.
  • Updated Return to Home settings with accurate timing options.
  • Added panic button to Security Sensor Page for enhanced experience.
  • Fixed issue with home button navigation redirecting to dashboard correctly.
