March 24, 2025
Linux Firmware v2.0.77.3053.1 [production-194]
New
Networking:
- Multi-step network configuration: multiple commands related to network settings passed as a single command.
- Support for output for the full version of the Wi-Fi network scanner was added.
Scenes:
- Action forwardNotifications:
- Indicates whether firmware supports new alert path;
- hub metadata passed along with the request, such as hub type, battery state. Available to use from templates.
Sensor Groups:
- Device groups of persistent policies are marked as persistent objects;
- CMS signal delay for armed+tripped events is calculated using entry delay and abort window according to a sensor group configuration.
Security System
- Alarmed state broadcasts: entry delay from the sensor group is used.
- Alarmed state phase "main" indication introduced.
Hybrid Notifications:
- The first version supports the hybrid notifications alert path fully.
Fixes & Improvements
Scenes:
- isBatteryState repeated scene runs fixed;
- isBatteryLevel was not triggering scene execution when a condition is met.
Hybrid notifications:
- forwardNotifications action:
- Device fields were not accessible for template builder: device name and others;
- A controller serial number template substitution data was added.
RF Team:
- Z-Wave addon reboot mechanism adjusted;
- Z-Wave ELECTRONIC LOCK LS-8076 device full support added.
July 9, 2024
Linux Firmware v2.0.59.2759.8 [production-176]
- We've added log level and timestamps to SSH Tunnels logging for improved troubleshooting.
- Reduced logs printed from WebSocket commands with large bodies to improve performance.
- When pressing SOS or Panic buttons, alarmDelay will no longer be set to 0.
- Error reporting has been updated for cameras.get_stream_info.
- Improved logging is now available for HttpLinks.
- We've corrected an issue where Walk test could not be extended or stopped due to the error "Walk test not started".
- Fied issue where the eth0 interface may remain "up" on some systems after unplugging the Ethernet cable, and no http_link_updated events were triggered.
- Updated the cameras plugin to correctly set the hub's IP address as destination for motion and ring events.
June 18, 2024
Linux Firmware v2.0.59.2759.2 [production-175]
- Added support for 2GIG and Honeywell generic device pairing flow.
- Added generic type for DW sensor with dry contact.
- Fixed some issues with August Smart lock inclusion.
- Addressed an issue with Truvision Camera stream.
- Added fixes and improvements for streaming on Onvif cameras.
- Integrated MediaMTX driver into the firmware for enhanced streaming capabilities.
- Implemented Control Group parameters and setup for MediaMTX.
- Implemented logging for snapshots checksum.
- Implemented logging for snapshots requests.
- Resolved issue with non-synchronized access to snapshots cache.
- Implemented updates to the ha-metrics service report.
- Add proactive reporting for uninterruptible_sleep, bcdc errors and kernel crashes.
- Add local mode http server metrics to proactive reporting.
- Resolved a condition preventing the proactive reporting watcher from sending data.
- Fixed an issue with time object showing a time in the future.
- Solved issue with the handler for uninterruptible sleep blocking due to hanged logcmd.
- Fixes related to extending the walk test.
- Fixed issue where the walk test is extended for more than 5 minutes.
- Now the fw correctly sends the status of the walk test when it's finished.
- Fixed issue with streaming on generic cameras after update to firmware prod-173.
- Corrected issue with outdated snapshots (24hour old).
- Improved logging for internal components to improve troubleshooting: arp table,
- firmware_status: system utilities: netifd, ssh, wpa_supplicant.
- Fixed issue with connection-checker script that was rebooting the controller even when internet was available.
- Updated arp table to use ip neighbor mechanism.
- Implemented predefined ContactID codes for Sensor Groups.
- Fixed issue with camera snapshots creation taking too long.
- Ensured all CO and smoke and glass break sensors are sending a security alert even when the
- system is disarmed.Added logging for bus.request.timeout.
- Corrected issue preventing Wi-Fi network scanning to stop.
- Fixed issue where multiple wifi interfaces were stored in /etc/config/wireless.
- Corrected issue with hub.scenes.block.status.reset returning an error.
- Added database version and number of devices to backups metadata.
- Fixed condition when hub.service.info.get for addon.cameras returned an empty streams list.
- Fixed issue with Explore action not being executed when the exception allows.
- Addressed issue where hub.scenes.stop finishes with error message: "Bus request timeout".
Comments
0 comments
