MiOS App Release Notes
Daniel Stefan
Daniel Stefan
  • Updated
March 13, 2025
MiOS Android App v1.114.0.930
New
  • Implemented the onboarding process for Ezlo Aware
  • Updated design for Ezlo Water Valve tiles and icons
  • Implemented Device Pairing wizards for:
    • Honeywell T10
    • Ecolink WST802
    • Savvi and Ecolink Sirens
    • Genie Aladdin Garage Openers- MyQ Garage Opener
Fixes & Improvements
  • Rare application crash on "Dashboard" view
  • Translation corrections for the device pairing wizards in Spanish (Fibaro RGBW Controller, GoControl Wireless Remote Switch WA00Z-1, GoControl Wireless Remote Switch WA00Z-1, Linear Dimmable Module PD300Z-2, Qubino Flush On/Off Thermostat ZMNHIDx, Qubino Flush On/Off Thermostat ZMNHIDx)
  • Devices created by Ezlo SiteSensor plugin were displayed as valid devices for Actions in Scenes4. Scenes with non-RGB bulbs were created incorrectly
February 28, 2025
MiOS iOS App v1.10
New
  • Implemented Ezlo Aware onboarding experience
  • Updated timeline design for camera records
    - Honeywell T10
    - Ecolink WST802
    - Savvi and Ecolink Sirens
    - Genie Aladdin
    - MyQ Garage Opener
  • The app now remembers the sensors set to "Disarmed" in House Modes configuration on iOS.
  • Fixed an issue in the app where the "At Home" option in House Modes could not be selected and the "Vacation" mode was missing.
  • EzloPi Addressable LED icon no longer appears as a motion sensor, but has a correct icon on the dashboard.
  • Fixed an issue where Yeelight bulbs could not be set to “On” using the switch item in Actions sections in the Meshbots.
January 27, 2025
MiOS Android App v1.114.0.821
New
  • MeshBot now support improved labeling and filtering on mobile devices.
  • Improved information display for OS level notifications on MiOS.
  • Local and Cloud Meshbots can now be duplicated in the MiOS App.
  • Improved onboarding flow for EzloPi mobile apps.
  • A new Water Valve category has been created for Z-Wave DPWs.
  • Updated device icons on the devices list screen.
  • Improved UI representation for Ezlo Aware item types.
  • Native Dashboard now supports displaying online and offline devices.
  • The device adoption process on EzloPi is fixed, preventing it from getting stuck due to an empty MAC address.
  • Newly added EzloPi devices now display immediately without needing to restart the app.
  • Fixed a double login issue in the app, enhancing the user login experience.
  • Fixed a crash in Mios Live when selecting a specific date as an activation event.
  • Fixed an issue where selecting 'Once' in the Date and Time node of Meshbots displayed an incorrect future date.
  • Fixed issue preventing the device status from updating correctly on the Devices screen.
  • VistaCams 703 and 1103 no longer appear under More > Doorbells in Mios.
  • The Smart Plug-In Outlet now displays the correct icon under Devices and is available on the Dashboard.
  • Creating a notification user now correctly assigns notification-only permissions instead of admin privileges.
  • Fixed an issue where the thermostat icon was not displayed properly.
  • Fixed the icon and value display for the Swidget Pressure sensor.
  • The scale displayed for the Swidget Air Quality Sensor has been corrected to IAQ.
  • Decimals for Swidget Air Quality Sensor values are now displayed without rounding.
  • Swidget Air Quality Sensor now displays a maximum of 2 decimals and includes pollution level descriptions from "Excellent" to "Dangerous."
  • Updated the Swidget Humidity Sensor icon in the MiOS app to match the design.
  • Device tiles are no longer cut off at the bottom of the native dashboard.
  • Fixed an issue preventing the addition of controllers through the MiOS app.
  • Fixed an issue where Meshbots could not be saved in the Mios app.
  • Translation corrections have been applied related to Private Label.
  • Fixed the missing resident account selection for installer accounts in the MiOS app.
  • Fixed app crash when editing a meshbot created incorrectly from the iOS App.
  • Fixed issue preventing the creation of Meshbots with Eltako ESB62NP-IP Shading actuator in the MiOS App.
  • Fixed an issue preventing the creation of meshbots using the Eltako EUD62NPN-IP/110-240V in the MiOS app.
  • On/Off button for Eltako ESR62NP-IP/110-240V is now available in the MiOS App's Devices View.
  • Fixed issue preventing the Eltako ESR62NP-IP/110-240V impulse switch from being used in Meshbots Device Actions.
  • On the Devices View in the MiOS App, the On/Off button for the Eltako ESR62PF-IP/110-240V can now be used to control the device.
  • Fixed an issue preventing the Eltako ESR62PF-IP/110-240V from being used in Meshbot Device Actions within the MiOS App.
  • The On/Off button for the Eltako Dimmer EUD62NPN-IP/110-240V is now hidden, displaying only the dimmer slider.
  • The order of the "Up" and "Down" buttons for the Eltako ESB62NP-IP shading actuator has been corrected in the MiOS App.
  • Updated the MiOS App to display the correct icon for the Eltako ESB62NP-IP / 110-240V Shading actuator.
  • Fixed an issue where the dimmer couldn't be set to 100% for the Eltako EUD62NPN-IP/110-240V.
  • Fixed an issue that was preventing the dashboard from loading successfully after exiting the camera stream.
  • Hue Lamps now display the correct OFF status when turned off in the app.
  • Fixed crash when selecting "Valid From" in Daily restrictions on MiOS.
  • New design implemented for MiOS app screens.
  • Timeline records in the MiOS App now display in the correct order.
  • Devices created by the Vacation Plugin now support "On/Off" buttons.
  • Fixed an issue with the dashboard displaying items incorrectly on smaller screens.
  • The dashboard now displays the complete list of devices.
  • Fixed issue where icons were missing for certain devices on the dashboard.
  • Fixed an issue where devices did not display on the dashboard when the app was opened.
  • Fixed a crash issue reported by Firebase Crashlytics.
  • Hue Lamps now correctly set dimmer values, with a minimum limit of 1.
  • Fixed the "Panel is Offline" error when saving restrictions on doorlock PIN codes in MiOS.
  • Fixed an issue where "No Cameras detected" was briefly displayed even when cameras were connected to the hub.
  • Camera preview on the "Devices" menu now displays quicker without the previous 4-5 second delay.
  • Fixed an issue where devices created by the Vacation Plugin were not available for use in Meshbots Actions.
November 28, 2024
MiOS iOS App v1.9
  • The camera speaker volume slider now displays the set value correctly and limits the range to 5-15.
  • Fixed an issue where recordings were not properly listed in the MiOS app.
  • Fixed issue preventing Property managers from logging out due to an infinite spinner display.
  • Fixed inconsistencies in the MiOS app, ensuring the most recent recordings are now displayed correctly.
  • EzloPi devices now appear correctly without needing to reopen the app after logging in.
  • Fixed an issue where daily restrictions could not be added to PIN codes when the mobile device was set to a 12-hour format.
  • Invalid MeshBot creation with Eltako ESB62NP-IP shading actuator has been fixed.
  • Fixed a crash in Mios when attempting to add a generic EzloPi device.
  • The "Welcome to Ezlo" screen now appears as expected after logging in with an EzloPi device.
  • EzloPi devices are now correctly represented, resolving the issue where they were misidentified as Ezlo Atom controllers.
  • Fixed several issues with the Swidget plugin:
    - corrected device icon for Volatile Organic Compound sensor
    - configured the Volatile Organic Compound sensor to support the display of decimals
    - corrected display issue with the value reported by the Pressure sensor
October 29, 2024
MiOS iOS App v1.8
New
  • Implemented the UI for Ezlo Aware devices in devices list.
  • Added design for the new Ezlo Aware tiles on the dashboard, as well as support for all child devices.
  • Fixed: Partner logo and branding colors now load properly on first login.
  • Fixed an issue where live streaming through relay was not working on VC702.
  • Fixed an issue where login was stuck causing the app to hang.
  • Fixed a condition causing app to crash when opened.
  • Fixed app crashing when pairing Ezlo Pi device with custom type.
  • Fixed crash issue when configuring EzloPi without Bluetooth connection.
  • App now correctly displays "Adopt unsuccessful" when configuring EzloPi device.
  • Fixed issue where adopting Ezlo Pi device resulted in a spinning wheel and adoption failure.
  • Fixed an issue where live stream did not load after playing a recording from the timeline.
  • Display measured values for Multi-sensor A8-9 in Device screen for improved user experience.
  • Fixed issue where Eltako Dimmer EUD62NPN-IP was incorrectly displaying On/Off button. The
  • device has only dimming capability.
  • Updated the icon for Eltako ESB62NP-IP Shading actuator in Meshbots when used as activation event or action.
  • Corrected display issues for multiple devices supported by the Swidget Plugin: Pressure Sensor, Air Quality Sensor, Volatile Compound Sensor and CO2 level sensors.
October 1, 2024
MiOS iOS App v1.7
  • Fixed issue with live streaming not loading from cameras section.
  • Fixed issue with recordings from the current day not showing in History.
  • Fixed issue with non-working options for EzloPi in My Controllers.
  • Fixed bug displaying tokens in Spanish translation.
  • Fixed missing graphics on "keep it up!" screens.
  • Resolved issue where the generic name for controller was not displayed on DPW.
  • Addressed condition causiing video recordings and snapshots not being displayed in History for doorbells/cameras.
  • Corrected various Spanish translation errors.
  • Fixed issue where private label tokens were displayed incorrectly.
  • Fixed issue where devices from Dashboard or 'Devices' menu could not be operated.
  • Fixed: EzloPi device with configured pins not visible in Devices.
  • Fixed tab bar issues in MiOS onboarding flow.
  • Fixed an issue with the camera sound being heard when speaker button was turned off.
  • Fixed issue with motion reporting not displaying under Devices screen.
  • Fixed issue with push notifications not working in MiOS app.
  • Fixed account deletion flow issues, now an email is correctly sent to the user about the start of the process.
July 17, 2024
MiOS iOS App v1.6.21
New Features
  • Native Dashboard
  • Support for EzloPi devices
  • Pin configuration support for EzloPi devices
  • Geofencing
Full changelog
The MIOS app now features a native dashboard as the default option for a seamless experience.
Introducing support for EzloPi devices with seamless pairing and intuitive UI configuration
  • Implemented provisioning, added EzloPi option in controllers type, and improved UI for Instructions, Detected devices, Configure WiFi, and Success screens.
     Fixes
  • App no longer crashes when trying to configure a device not connected via Bluetooth.
  • My Controllers now accurately displays available options for EzloPi devices.
  • Enabled operation of EzloPi devices from Dashboard or 'Devices' menu.
  • Corrected issue where Generic EzloPi device with configured pins didn't appear in the Devices list.
Introducing pin configuration for EzloPi devices in the iOS mobile app
     Implemented features
  • View and manage existing EzloPi device configurations.
  • Correctly display configured EzloPi devices on dashboard and devices list.
  • Configure EzloPi devices with various types: Digital Input, Analog Input, PWM, UART, One Wire, I2C, and Other.
  • Choose to keep existing device ID or create a new one and enter Wi-Fi credentials for the network.
  • Select chip type for EzloPi devices.
  • View a list of existing configurations.
  • View configuration type options.
Introducing Geofencing on iOS mobile app
  • List Screen for geofences.
  • Map screen for visualizing geofence locations.
  • Settings popup for configuring geofence settings.
  • Add/Edit screen for creating and editing geofence entries.
  • Support for geofence in scenes, allowing for location-based automation.
  • Scenes block implementation for scene-based automation.
  • Active device logic implementation.
  • Registered geofences to be monitored by the phone, enabling location-aware features.
     Fixes
  • Fixed error on Meshbot activation event.
  • Corrected issue with location limit not being set.
  • Arrow icon will now be removed when deleting geofences for a cleaner user experience.
  • Token no longer displayed when editing locations.
  • Geofences can now be used as a trigger for meshbots as expected.
  • An issue with the LocationManager was resolved, preventing errors and improving performance
General fixes
  • Resolved issue where users couldn't add Smart Start devices by entering DSK codes manually.
  • Snapshots are now correctly displayed under Cameras/Doorbells > History in the MIOS app.
  • A manual input field has been added to set the Z-Wave Dimmer Duration setting value via the mobile app.
  • Fixed issue showing a token in the Scene controller ButtonControls screen.
  • Select connection security screens will now only appear once, without duplication.
  • Users can now save their time zone settings on Water Valve hubs without issues.
  • Camera previews are now showing correctly on the Devices/Cameras page.
  • Corrected an issue where a dialog was incorrectly displayed on the login screen of the app after installation.
  • The onboarding loop has been fixed to prevent unnecessary redirects during setup.
  • Fixed condition causing a crash while opening the Device Pairing Wizard (DPW).
  • Device icons are now displaying the correct status consistently.
  • The capabilities and state of Scene controller buttons are now displayed correctly.
  • Fixed a corner case where a newly paired device would not be visible on the UI.
  • Manufacturer specific thermostat modes are now displayed on the UI as expected.
  • Heat sensor icons are once again visible in the MIOS app.
  • Fixed a condition causing the Include/Exclude buttons to not be visible on the Devices Screen randomly.
  • Users can now select a security level during device inclusion.
  • Siri Shortcuts functionality has been fixed and will no longer stop working after 24 hours.
July 12, 2024
MiOS Android App v1.114.0.561
New features
  • We've improved the account cancellation process in our MiOS App, making it easier for users to manage their accounts.
  • The Device screen now correctly displays measured values from the MCO Home A8 9in1 sensors.
Fixes
  • Users can now create Pincodes without encountering issues.
  • We've added support for displaying measured values from CO2 Level Sensor, Loudness Sensor, Particulate Matter 2.5 Sensor, Smoke Density Sensor, and Volatile Organic Compound Level Sensor.
  • The "More" section of the app is now displayed correctly even if a user doesn't have controllers, making the experience more consistent.
  • Delete icon was removed from the Account Administrator - User edit screen to simplify the interface. The user can still use the "Delete My Account" item in the menu.
  • Users can now set PIN codes for doorlocks using the MiOS app without encountering issues.
  • Selecting and unselecting check marks on Meshbot actions is now functioning as expected.
  • Recordings > History menu no longer displays duplicate entries, providing a more accurate experience.
Was this article helpful?
1 out of 1 found this helpful
Comments
0 comments
