EZlogic & Dashboard Release Notes
Daniel Stefan
Daniel Stefan
  • Updated
February 4, 2025
Resident Portal v2.9.2
Fixes & Improvements
  • Fixed UI error that incorrectly displayed a failure message when a plugin was successfully added to the private space.
  • Solved an issue with the Marketplace not displaying the list of available plugins.
January 27, 2025
EZlogic v2.9.1
  • Exceptions in Meshbot now persist after modifications to fields or names.
  • Dates on the Backups page now display correct English abbreviations for January and December instead of French.
  • Added capabilities for new_guest_user and guest_user_revoke in the notification templates for Short Term Rental.
  • Added support for force send email in two notifacation templates for property creation and deletion notifications specific to Short Term Rental.
  • Fixed an issue where user-associated controllers were not displayed in the Edit User section.
  • Several methods like isDeviceState, compareValues, setDeviceArmed, switchHouseMode, as well as Group Operations are now available for ezlopi devices on specefic firmware versions.
  • Implemented several improvements for logging for more efficient troubleshooting and issue resolution in certain cases.
January 9, 2025
EZlogic 2.8.1
New
  • Account cancellation capability has been added to the UI.
  • HTML body validation has been implemented for notification templates, Local MeshBot notifications and Cloud MeshBot notifications
  • Handled cloud keys in notification template for HTML validation.
  • Reduced unnecessary calls to the Notification Categories API when user accounts are opened without categories.
  • Improved handling for scenarios with no pin code devices.
  • Blocked the popup display for saving a pincode after creation or editing.
  • Optimized data compression for the integrations_preview request to enhance memory management and prevent crashes.
  • Fixed an issue where body HTML was missing in Scene_Set payload after user modifications in notifications.
  • BODY HTML is now hidden in MeshBot notifications when the Email Channel is unchecked.
  • Fixed incorrect validation when rechecking the Email Channel in Local Meshbot Notifications.
  • Subject values now retain their entries when rechecking the email channel in Local MeshBot Notifications.
  • The "Edit Unsaved" dialog no longer appears in Cloud Notifications when no changes are made.
  • Fixed an issue with the validation stripe appearing in edit mode when adding a new trigger in edit mode.
  • Fixed a validation issue in the Cloud Notification block that incorrectly displayed a red stripe for valid inputs and failed to show errors for invalid HTML.
  • Fixed validation issue in system meshbot templates.
  • Fixed issue where the Save button in IP Template edit mode was not enabled after uploading an image.
  • Fixed the responsive issue on the Customization Nodes & Controllables page in Ezlogic.
  • Added missing trigger functions to the group creation process in EZLogic.
  • Fixed a bug causing a 400 error when downloading plugins from Ezlogic.
  • Fixed responsive and UI issues on the customization menu page.
  • Resolved an issue where deleting Device Z-Wave Associations required a browser refresh after each deletion.
  • Fixed issue where the selected option from the project dropdown was not displayed in the virtual container field.
  • The Save button for Meshbot creation/editing now disables after the first click to prevent multiple submissions and includes a loader to indicate the save process.
  • Fixed incorrect display of the drop-down list in MeshBots actions when the Cloud Service is selected.
  • Incorrect response tree mapping for fields with "array" type and missing type property has been resolved in the "integrations_preview" query.
  • The display of fields for cloud integrations has been fixed to ensure proper functionality.
    Fixed incorrect response tree mapping when the array is in the root part of the response tree.
November 14, 2024
Dynamic Dashboard v1.1.29
New
Added UI for Ezlo Aware sensors including:
- temperature
- humidity
- presence
- pressure sensors
- air quality
- sound sensor
- marijuana
- vape
- smoke sensor
  • Updated dashboard tiles for multiple Swidget Devices:
    - Power/Electric Meter
    - Humidity Sensor
    - Temperature Sensor
    - Pressure Sensor
    - CO2 level sersor
    - Air Quality Sensor
  • The fullscreen button on the camera stream is now functioning correctly.
  • MQ2 Gas Sensor Analog device now appears on the Dynamic Dashboard as a tile.
  • Resident portal dashboard now switched to OpenWeather as the weather service provider.
  • Fixed an issue where the dashboard would get stuck loading when no devices were available.
  • Fixed the dashboard to correctly send "hub.videoforward" commands when WebRTC v1 is not enabled.
  • Fixed issue with cut-off text in the thermostat tile on the dynamic dashboard.
  • Fixed issues with the Philips Hue plugin caused incorrect light states to display.
November 8, 2024
EZlogic v2.7.1
Major improvements to conditions for automatic events from devices using System Meshbots for Security Alerts and Events broadcasts.
- This upgrade enhances the intelligent detection capabilities, allowing System Meshbots to automatically generate more accurate and relevant triggers and notifications.
New features and Improvements
  • Daily event history is now displayed on a single page, without pagination.
  • Alerts and events history now includes visual icons throughout the page.
  • Controller selection display now shows even when a controller is offline.
  • Improved page navigation: alerts and history remain visible when switching pages, pagination arrows update dynamically on successful page loads.
  • Different colors for events have been implemented based on specific conditions, including security sensor events, doorbell ring events, and mode changes.
  • Unknown events with deviceName, name, valueFormatted, or value fields are now displayed.
  • Alerts history updated to display only configured event types.
  • Improved Alert and Event History View: Page-based navigation, filtering, and pagination features added for enhanced record browsing.
  • Implemented Spanish event translations in Security Alerts and History.
  • Logged unknown events with detailed broadcast data for future processing and tracking.
  • Implement log entry for unknown security alerts and events in Alerts and events history.
  • Filtering by source in Alerts/History is now fully functional.
  • Corrected colors for Arm (Stay) and Arm (Away) alerts: now displays as expected with Arm (Arm (Away)) showing in red, Arm (Stay) in orange, and Disarmed events in green.
  • System Arm/Disarm notifications no longer duplicate upon execution.
  • Now it is possible to Enable/Disable Cloud MeshBots.
  • Updated the Partner meshbot template to force send email notifications for password resets.
  • Cloud services are now sorted in alphabetical order.
  • Fixed an issue where device capabilities in EZLogic PAAS 2 were not functioning properly.
  • Resolved intermittent issue where the Ezlogic Plugins area failed to show the installed controller on Manage Installations buttons.
  • Fixed logo display issue on the Customizations page.
  • Fixed an issue with the action section dropdown in notification templates page, causing it to crash.
  • Fixed issue preventing users from adding EzloWeather and other accounts on the Cloud Services page.
  • Fixed an issue that prevented the deletion of cloud integrations enrollments.
  • Corrected issue with sidebar validation color in Cloud and Local Mashbot when some required fields are missing.
  • Fixed incorrect form display issue when selecting a method from the dropdown in the Cloud and Local Mashbot.
  • Corrected minor display issues with the Philips Hue Plugin.
  • Improved the Device Settings Menu for Z-Wave Devices in Ezlogic for better accuracy.
  • Fixed an issue where a specific call was called on every login instead of only for configuration.
October 22, 2024
EZlogic v2.5.4
  • Resolved issues with the Philips Hue Plugin update, including dialog text corrections and device count discrepancies.
September 2, 2024
Dynamic Dashboard v1.1.27
  • Fixed issue where the Dashboard was sending wrong command instead of hub.videoforward
August 22, 2024
Dynamic Dashboard v1.1.26
Fixes and improvements
  • Added dashboard storage redirect support for cloud storage methods, providing increased speeds.
  • Fix for RGB-CCT light color picker issue, it now sends CW-WW values to firmware correctly.
    Improved WebRTC capabilities for seamless video and audio communication.
  • Stream connections now retry exponentially on failure.
  • Improved live streaming functionality for cameras with refactored recovery mechanism.
  • Now a loading indicator and message are displayed on videos while they are being retrieved.
  • Nest thermostat tile now allows changing setpoint to a higher value after mode change.
  • Thermostat temperatures now clearly display in both Celsius and Fahrenheit formats on the dynamic dashboard.
  • Resolved thermostat mode display issue on dashboard.
  • Reduced unwanted network requests for video elements.
  • Values are now correctly displayed for IP Devices.
  • The Aeotec ZWA008-C door/window tilt sensor status is now accurately displayed on the dashboard.
August 20, 2024
EZlogic v2.5.2
  • Improved Meshbot Trigger Experience: The list of node types is now consistently displayed.
Was this article helpful?
0 out of 0 found this helpful
Comments
0 comments
