Ezlo Z-Wave Thermostat Installation Manual
Sara
Sara
  • Updated
Model: EZL-TSTAT-US
Enjoy the ultimate in comfort, convenience, and energy efficiency
Introduction
Thank you for choosing the Ezlo Z-Wave Thermostat
You’ve taken the first step toward making your home smarter and safer.
We want setting up to be as easy as possible but if you’re finding yourself in need of help, our outstanding human customer care is for you through the following channels:
Call.png Toll-free number 866 966 2272
Call.png International number 702 487 9770
mail.png support@ezlo.com
web.png support.ezlo.com
Important tips
Before pairing your new Ezlo Thermostat to your home
controller, set the parameters to adjust the
thermostat's behavior. See Menu description and
Z-Wave parameters sections | pages 24–28 and 34–39.
If your Ezlo Thermostat has already been paired with
your home controller and you want to change the
parameters, please note that an exclusion and pairing
again will be required to update the UI controls and
thermostat capabilities on your controller.
Getting Started
Pairing with a Z-Wave Hub
Follow these quick steps to get up and running.
Each step includes a reference to where you can find the full procedure in this manual.
Wiring Setup
Begin by removing your existing thermostat and connecting the Ezlo Thermostat according to your HVAC system type.
  • Turn off power to your HVAC system.
  • Label existing wires before disconnecting them.
  • Mount the Ezlo base plate and wire the unit as per your system (conventional or heat pump).
  • Follow wiring diagrams and terminal descriptions for your specific system.
Continue on page 10–22 for the full wiring
instructions.
Thermostat Configuration
After wiring, configure the thermostat through its interface:
  • Power up the device.
  • Use the Secret Menu to set your HVAC system type.
  • Adjust display, fan, schedule, and offset settings as needed.
  • Set your preferred temperature units and other preferences.
Continue on page 23–28 for full configuration details.
Connect the thermostat to your smart home
system:
  • Open your Z-Wave controller’s app (e.g., MiOS for Ezlo hubs).
  • Put the controller in inclusion mode.
  • On the thermostat, press and hold ▲+▼ for 3
    seconds to access Z-Wave menu.
  • Press ⦾ to enter learning mode.
Continue on page 30–31 for complete pairing instructions.
Once you've completed these steps, you're ready to enjoy smart, efficient climate control with your Ezlo Thermostat.
Product Description
Enhance your home’s heating and cooling. Easily control temperature to your liking with the MiOS App, immediate response when you arrive home and save on energy costs. With Z-Wave connectivity and a user-friendly interface, managing your home’s temperature has never been easier. Upgrade to the Ezlo Thermostat and experience the perfect blend of comfort and technology. Imagen7.png
Product Specifications
Power Supply AC/DC 24V / 4*AAA dry battery (device will enter low power working state)
Application range gas/fuel boiler, electric heating, water heating, heat pumps & more
Frameless Display Tempered glass +PC+ABS
Self-Consumption <1W
Resistive Load <1A
Temp. Setting Range
32°F to 99°F (0°C to 40°C)
Precision 0.1 °C (1 °F)
Control Type
HVAC
Wire Connection Terminal
Dimension 113×113×19mm (4.45×4.45×0.75 inches)
Mounting
60.3mm (2.37 inches) hole pitch
Communication Protocol
Z-Wave 904.42 MHz with S2 encryption
Certifications
FCC
  • Application range: gas/fuel boiler, electric heating, water heating, heat pump etc. 8 types control systems.
  • Z-Wave 800 series.
  • Touch button operation interaction.
  • Simpler way to connect wires without screw driver.
  • Built-in temperature sensor for ambient temperature reading.
  • Battery Powered: Easy installation without the need for hardwiring.
Package Contents
  • 1x Thermostat
  • 1x Back plate
  • 4x Wall anchors
  • 4x Wall mounting screws
  • 2x Base plate securing screws
Required (not included)
  • Philips head screwdriver
  • Flat head screwdriver
  • 4x AAA Batteries
Wiring Cautions/ Wiring Notes
Ezlo Thermostat Front Plate Removal / Disassembly
Installation Steps
  • Remove the old thermostat if you have an existing one
  • Dissasemble the front plate of the Ezlo Z-Wave Thermostat (fig.1)
  • Attach the base plate to the wall and pull the existing wiring through the base plate (fig.2)
  • Re-attach the front plate to the back plate (fig.2)
  • Wire the Ezlo Z-Wave Thermostat for your specific HVAC system
  • Add the thermostat to your Z-Wave Network
Removing the Existing Thermostat
Terminal Typical Wire Color Function
Y Yellow Cool
W White Heat
G Green Fan
R Red 24VAC Return
C Blue 24V Common (typically BLUE)
Wiring the Ezlo Z-Wave Thermostat for your specific HVAC system
    Terminals need to be wired Wiring Diagram Reference
Item Description G   Y1 Y2 W1 W2 O/B
0 One-stage Conventional cool only Dot.png Dot.png         Fig.0
1 Two-stage Conventional cool only Dot.png Dot.png Dot.png       Fig.1
2 One-stage Conventional heat only Dot.png     Dot.png     Fig.2
3 One-stage Conventional heat only(no fan)       Dot.png     Fig.3
4 Two-stage Conventional heat only Dot.png     Dot.png Dot.png   Fig.4
5 One-stage Conventional heat & coo Dot.png Dot.png   Dot.png     Fig.5 Fig.5-2
6 Two-stage Conventional heat & cool Dot.png Dot.png Dot.png Dot.png Dot.png   Fig.6 Fig.62
7 One-stage Cool in heat pump Dot.png Dot.png       Clear dot.png Fig.7
8 Two-stage Cool in heat pump Dot.png Dot.png Dot.png     Clear dot.png Fig.8
9 One-stage heat in heat pump (optional: Aux) Dot.png Dot.png     Clear dot.png Clear dot.png Fig.7 Fig.9-2 Fig.9-3
10 Two-stage heat in heat pump (optional: Aux) Dot.png Dot.png     Clear dot.png Clear dot.png Fig.8 Fig.10-2 Fig.10-3
11 One-stage heat & cool in heat pump (optional: Aux) Dot.png Dot.png     Clear dot.png Dot.png Fig.11 Fig.11-2 Fig.11-3
12 Two-stage heat & cool in heat pump (optional: Aux) Dot.png Dot.png Dot.png   Clear dot.png Dot.png Fig.12 Fig.12-2 Fig.12-3
Wiring Terminals Description
Terminal Description
R (Red) Power for heating--connect to secondary side of heating system transformer
RC Power for cooling--connect to secondary side of cooling system transformer
C Common wire from secondary side of cooling or heating system transformer
W Heat relay (stage 1)
W2 Second stage heat relay or auxiliary heat relay
OB Changeover valve for heat pump systems
Y Compressor contactor (stage 1)
Y2 Compressor contactor (stage 2)
G Fan relay
K Wire with 4-5 module
NC
Installation Wiring For Conventional Systems
Installation Wiring For One-stage Conventional Cool Only
Installation Wiring For Two-stage Conventional Cool Only
Installation Wiring For One-Stage Conventional Heat Only
Installation Wiring For One-stage Conventional Heat Only (no fan)
Installation Wiring For Two-stage Conventional Heat Only
Installation Wiring For One-stage Conventional Heat & Cool (Single Transformer)
Installation Wiring For One-stage Conventional Heat & Cool (Double Transformer)
Installation Wiring For Two-stage Conventional Heat & Cool (Single Transformer)
Installation Wiring For Two-stage Conventional Heat & Cool (Double Transformer)
Installation Wiring For Heat Pump Systems
Installation Wiring for One-stage Cool in Heat Pump & One-Stage Heat in Heat Pump (no auxiliary heat)
Installation Wiring for Two-Stage Cool in Heat Pump & Two-stage Heat in Heat Pump (no auxiliary heat)
Installation Wiring for One-stage Heat in Heat Pump (with auxiliary heat) Single Transformer
Installation Wiring for One-stage Heat in Heat Pump (with auxiliary heat) Double Transformer
Installation Wiring for Two-Stage Heat in Heat Pump (with auxiliary heat) Single Transformer
Installation Wiring for Two-Stage Heat in Heat Pump (with auxiliary heat) Double Transformer
Installation Wiring for One-stage Heat & Cool in Heat Pump (no auxiliary heat)
Installation Wiring for One-stage Heat & Cool in Heat Pump (with auxiliary heat) Single Transformer
Installation Wiring for One-stage Heat & Cool in Heat Pump (with auxiliary heat) Double Transformer
Installation Wiring for Two-Stage Heat & Cool in Heat Pump (no auxiliary heat)
Installation Wiring for Two-Stage Heat & Cool in Heat Pump (with auxiliary heat) Single Transformer
Installation Wiring for Two-Stage Heat & Cool in Heat Pump (with auxiliary heat) Double Transformer
Thermostat Display Overview
Menu Description
Menu Number Item Range Default Description
1 Temp. Unit C/F F C: Celsius F: Fahrenheit
2 Power Failure Memory 0-1 1 When power on again: 0: Device will be in shutdown state (OFF). 1: Device will stay the last status of working mode.
3 SCREEN OFF 0-90min 1min Automatic screen off time, When the device is charged by C&R port: 0: The screen will not turn off
automatically; Set 1-90mins to automate turn off the screen. When the device is powered by battery:
Set 3-90secs to automate turn off the screen; 0-2: After 8sec the screen will be turned off automatically.
4 Beep Set 0-1 1 0: OFF, 1: ON
5 Backlight Brightness 0-8 8 1-8: 8 level backlight brightness, 1 is the dimmest, 8 is the brightest
6 Temp. Upper Limit 1-99°C / 1-99°F 37°C / 98°F Temp. upper limit value, accuracy n*1
7 Temp. Lower Limit 0-99°C / 1-99°F 5°C / 41°F Temp. lower limit value, accuracy n*1
8 Temp. Offset -99~99°C /
-99°F-99°F
0°C / 0°F Temp. offset value(°C or °F ), accuracy 0.1 (n*0.1)
9 Humidity Offset -20~+20 0 Humidity offset value
10 Fan and Humidity Display Select 0-3 0 0: The most simplest display, fan mode and humidity will not display.
1: Display fan mode
2: Display humidity
3: Display fan mode and humidity
11 Panel Lock 0-3 0 0: Disabled 1: Secret Menu operation is invalid, except for modifying parameter 11, other operation is valid.
2: Secret Menu operation, changing mode and setpoint is invalid, only valid for adding/removing network or modifying parameter 11.
3: Only valid for adding/removing network.
12 1st Temp. Hysteresis 3-90,n*0.1°C /
3-90,n*0.1°F
10 / 20 Specifies the minimum temperature difference between the room temperature and the desired setpoint before the first stage of heating or cooling is allowed to turn on. (0.3-9 degrees).
13 2nd Temp. Hysteresis 3-90,n*0.1°F /
3-90,n*0.1°C
10 / 20 Specifies the additional minimum temperature difference after the first stage turns on before the second stage is activated. (0.3-9 degrees)
14 3rd Temp. Hysteresis 3-90,n*0.1°F /
3-90,n*0.1°C
10 / 20 Specifies the additional minimum temperature difference after the second stage turns on before the third stage is activated. (0.3-9 degrees)
15 System Control Type 0-12 12
0: One-stage Conventional cool only
1: Two-stage Conventional cool only
2: One-stage Conventional heat only
3: One-stage Conventional heat only (no fan)
4: Two-stage Conventional heat only
5: One-stage Conventional heat & cool
6: Two-stage Conventional heat & cool
7: One-stage Cool in heat pump
8: Two-stage Cool in heat pump
9: One-stage heat in heat pump (optional: Aux)
10: Two-stage heat in heat pump (optional: Aux)
11: One-stage heat & cool in heat pump (optional: Aux)
12: Two-stage heat & cool in heat pump (optional: Aux)
16 Changeover Valve Logic 0-1 0 0=When the heat pump starts cooling, O/B turns on; when the heat pump starts heating, O/B turns
off 1=When the heat pump starts heating, O/B turns on; when the heat pump starts cooling, O/B turns off
17 Compressor Protection Time 0~10min 1min The setting of compressor delay time from shutdown to startup, unit: min
18 EM Emergency (AUX) Heat Mode 0-1 0 1: ON 0: OFF Note: This mode is only valid for heat pump system with heating function
19 Time Display Selection 0-2 0
When Schedule function is activated:
0: Time, week, current time period displays.
1: Week and current time period displays.
2: Time, week and current time period does not display.
20 Fan Shutdown Delay Time 0-127 0 This parameter is valid only when the fan mode is AUTO. 0: When the compressor is shut down, the fan is also shut down. 1-127: The fan shuts down in a delay of n*minutes after the compressor is shut down, unit: minute
21 Compressor delay countdown display 0-1 0
0: No Display
1: Display
22 Whether to enable electrical auxiliary heat 0-1 1
0: Disable
1: Enable
98 RESET FACTORY 0-1 0 1: Restore factory setting
99 Firmware Version (Read only) -- 1 1-255
Navigating the Thermostat menu
Setpoint Setting
To adjust the desired indoor temperature:
  1. Press the "▲" (up) or "▼" (down) button.
  2. The "SET" icon will appear on the screen,
    indicating that you are in setpoint adjustment mode.
  3. Use the buttons to choose your desired
    temperature:
    • In Celsius: Range is 5°C to 37°C, adjustable in 0.5°C increments.
    • In Fahrenheit: Range is 41°F to 98°F, adjustable in 1°F increments.
  4. Once you’ve selected your desired temperature, press any button to save the setting and exit.
Mode Setting
  1. With the screen on, press • — the mode icon will flash.
  2. Press • again to cycle through modes:
    • OFF→HEAT→COOL→AUTO→AUX
    (Emergency Heating)
  3. Press ▲,▼, or set • to confirm the desired mode.
    The MODE icon will stop flashing.
Fan Mode & Schedule Setting
  1. With screen on, long press • for 3 sec to enter settings.
  2. Sequence: FAN MODE→SCHEDULE MODE→WEEK→TIME→EXIT
  3. Use ▲ or ▼ to change values (icon flashes), press • to confirm.
  4. If SCHEDULE MODE is enabled, the “SCHEDULE” icon will appear on the main screen.
  5. Long press • for 1 sec or no input for 20 sec = Exit.
Fan Modes
Fan On: The fan runs continuously when the
thermostat is on. It stops only when the device is turned off.
Fan Auto: The fan runs only when heating or
cooling is active. It stops automatically when the system is idle or off.
Secret Menu
With the thermostat set to OFF, press and hold "▼"+ "•" for 3 seconds to enter the parameter settings.
Use "▼" or "▲" to scroll through parameter values.
Press • to move to the next setting.
To exit, press and hold "▼"+"•" for 1 second, or wait 20 seconds without activity.
Thermostat Setup for Each System Type
Once the thermostat wiring is complete, enter the Secret Menu to configure the system type settings.
This ensures the thermostat operates correctly in the desired mode (Heat, Cool, Auto, etc.).
  • Before pairing your new Ezlo Thermostat to your home controller, set the parameters to adjust the thermostat’s behavior. See Menu description and Z-Wave parameters sections |
    pages 23–28 and 35–39.
  • If your Ezlo Thermostat has already been paired with your home controller and you want to change the parameters, please note that an
    exclusion and pairing again will be required to
    update the UI controls and thermostat
Secret menu .15 - System Type Configuration
(Possible Values 0-12)
Default Value: 7
0: One-stage Conventional Cool Only
1: Two-stage Conventional Cool Only
2: One-stage Conventional Heat Only
3: One-stage Conventional Heat Only (No Fan)
4: Two-stage Conventional Heat Only
5: One-stage Conventional Heat & Cool
6: Two-stage Conventional Heat & Cool
7: One-stage Cool in Heat Pump
8: Two-stage Cool in Heat Pump
9: One-stage Heat in Heat Pump (Optional: Aux)
10: Two-stage Heat in Heat Pump (Optional: Aux)
11: One-stage Heat & Cool in Heat Pump (optional: Aux)
12: Two-stage Heat & Cool in Heat Pump (optional: Aux)
Note:
See pages 24–26 for additional settings that may
need to be adjusted based on the selected system
type. These can also be configured via Z-Wave
parameters listed on page 34–39.
Standby & Backlight Brightness Settings
1. The screen will turn off automatically when
there is no user interaction.
Default time: 8 seconds when powered by
batteries, 1 minute when powered by 24V.
2. When the screen is on, pressing the top button
turns it off.
Note: Pressing any button will turn the screen
back on.
3. Long-pressing the top button temporarily
adjusts the screen brightness.
Notes: If the screen is off, this will turn it on.
The brightness will return to the value set in the
Secret Menu or via Z-Wave configuration.
4. Display of fan mode and humidity icons can be
enabled/disabled through the Secret Menu or
Note: These icons are hidden by default.
5. When the Schedule function is enabled, the
current time, weekday, and time period icons
can also be enabled/disabled through the
Secret Menu or Z-Wave configuration.
Note: These are shown by default.
Including the Z-Wave Thermostat to an Ezlo Z-Wave Hub
Step 1: In the MiOS app
1. Open MiOS and go to "More."
2. Select "Devices" and tap the "+" in the top right.
3. Choose your Ezlo Z-Wave Hub from the controller list.
4. Select "Thermostats" and select "Ezlo Thermostat" from the list
5. Follow the pairing instructions provided by the Wizard.
Step 2: On your Ezlo Z-Wave Thermostat
1. Press and hold "▼" and "▲" for 3 seconds to open the Z-WAVE menu.
2. If the thermostat is not connected, "---" will appear. Otherwise, the node ID is shown.
3. Press "•" to enter learning mode.
Note: Follow the same steps to exclude the device from the network. When removed from the Z-Wave network, the device restores it’s Z-Wave factory setting.
Including the Z-Wave Thermostat to other Z-Wave compatible hubs
Note: First, check the manual of the specific third party compatible how to include Z-Wave devices.
Step 1: Put the Z-Wave hub in including Mode.
Step 2: On the Thermostat
• Press and hold "▼" and "▲" for 3 seconds to open the Z-WAVE menu.
• If the thermostat is not connected, "---" will appear. Otherwise, the node ID is shown.
• Press “•” to enter learning mode.
Note: Follow the same steps to exclude the device from the network. When removed from the Z- Wave network, the device restores it’s Z-Wave factory setting.
Z-Wave Command Classes
S2 Supported
COMMAND_CLASS_VERSION
COMMAND_CLASS_DEVICE_RESET_LOCALLY
COMMAND_CLASS_BATTERY
COMMAND_CLASS_THERMOSTAT_SETPOINT
COMMAND_CLASS_THERMOSTAT_OPERATING_STAT
COMMAND_CLASS_THERMOSTAT_FAN_STATE
COMMAND_CLASS_TIME_PARAMETERS
COMMAND_CLASS_ASSOCIATION
COMMAND_CLASS_ASSOCIATION_GRP_INFO
COMMAND_CLASS_MANUFACTURER_SPECIFIC
COMMAND_CLASS_POWERLEVEL
COMMAND_CLASS_SENSOR_MULTILEVEL
COMMAND_CLASS_THERMOSTAT_MODE
COMMAND_CLASS_THERMOSTAT_FAN_MODE
COMMAND_CLASS_TIME
COMMAND_CLASS_CONFIGURATION
COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION
COMMAND_CLASS_FIRMWARE_UPDATE_MD
Non S2 Support
COMMAND_CLASS_ZWAVEPLUS_INFO
COMMAND_CLASS_SECURITY_2
COMMAND_CLASS_TRANSPORT_SERVICE
COMMAND_CLASS_SUPERVISION
Z-Wave Association Groups
AG ID Max Node ID Command Class Trigger situation
0x01 0x01 COMMAND_CLASS_SENSOR_MULTILEVEL_V5, SENSOR_MULTILEVEL_REPORT_V5 The change between the current detected temperature and the last reported gateway temperature is greater than the value set in parameter 2. The change between the current detected humidity and the last reported gateway humidity is greater than the value set in parameter 3.
    COMMAND_CLASS_THERMOSTAT_MODE_V2, THERMOSTAT_MODE_REPORT Thermostat mode changes
    COMMAND_CLASS_THERMOSTAT_OPERATING_ STATE, THERMOSTAT_OPERATING_STATE_REPORT Thermostat status changes
    COMMAND_CLASS_THERMOSTAT_SETPOINT_V2, THERMOSTAT_SETPOINT_REPORT_V2 Set point value changes
    COMMAND_CLASS_THERMOSTAT_FAN_MODE, THERMOSTAT_FAN_MODE_REPORT Fan mode changes
    COMMAND_CLASS_THERMOSTAT_FAN_STATE, THERMOSTAT_FAN_STATE_REPORT Fan status changes
    COMMAND_CLASS_DEVICE_RESET_LOCALLY, DEVICE_RESET_LOCALLY_NOTIFICATION Restore factory setting
    COMMAND_CLASS_BATTERY, BATTERY_REPORT The change in battery power is greater than 5%
Z-Wave Parameter Settings
Number Name Size Information Default Possible
Values
1 Temp. Unit 1 Secret menu No. E20: 0: Celsius 1: Fahrenheit 0 0-1
2 Temp. Difference
Reporting
2 Unit 0.1°C 0: Disabled 3-255: n *0.1°C automatically
report the temperature to the gateway when
temperature variation greater than this value
5 0, 3-255
2 Temp. Difference
Reporting
2 Unit 0.1°F 0: Disabled 3-255: n *0.1°F automatically
10 0, 3-255
3 Humidity
Difference
Reporting
1 0: Disabled 1-99: Automatically report the humidity
to the gateway when humidity variation greater
than this value
4 0-99
12 Power Failure
Memory
1 Secret menu No. E2 When power on again: 0:
1 0-1
13 SCREEN OFF 1 Secret menu No. E3 Automatic screen off time,
screen will not turn off automatically; Set 1-90mins
powered by battery: Set 3-90secs to automate
1 0-90
14 Beep Set 1 Secret menu No. E4: 0:OFF 1:ON 1 0-1
15 Backlight
Brightness
1 Secret menu No. E5: 1-8: 8 level backlight
8 1-8
16 Temp. Upper
Limit
1 Secret menu No. E06: Temperature upper limit
value, accuracy n*1
37 (°C)
98 (°F)
1-99
17 Temp. Lower
Limit
1 Secret menu No. E07: Temperature lower limit
value, accuracy n*1
5 (°C)
41 (°F)
0-98
18 Temp. Offset 1 Secret menu No. E08: Temperature offset value
(°C or °F) , accuracy 0.1 (n *0.1
0 (-99~+99) (°C)
(-99~+99) (°F)
19 Humidity Offset 1 Secret menu No. E09: Humidity offset value 0 -20~+20
20 Fan & Humidity
Display Select
1 Secret menu No. E10: Fan and humidity display
mode selection 0: The most simplest display, fan
mode and humidity will not display. 1: Display fan
mode 2: Display humidity 3: Display fan mode and
humidity Note: When schedule function is enabled,
the time, week, and time period are displayed, if
the humidity display at the same time, the
humidity and time are displayed alternately.
0 0-3
21 Panel Lock 1 Secret menu No. E11: 0: Disabled 1: Secret menu
parameter 11, other operation is valid. 2: Secret
modifying parameter 11. 3: Only valid for adding/
removing network.
0 0-3
22 1st Temp.
Hysteresis
1 Secret menu No. E12: accuracy: 0.1, Specifies the
turn on. (0.3-9 degrees). For example, if the heat
setpoint is 68° and the 1st stage hysteresis is set to
2 degrees, the room temperature will need to reach
66° before the heat turns on.
10 (°C)
2 (°F)
3-90 (°C)
3-90 (°F)
23 2nd Temp.
Hysteresis
1 Secret menu No. E13: accuracy: 0.1, Specifies the
10 (°C)
20 (°F)
3-90 (°C)
3-90 (°F)
24 3rd Temp.
Hysteresis
1 Secret menu No. E14: accuracy: 0.1, Specifies the
10 (°C)
20 (°F)
3-90 (°C)
3-90 (°F)
25 System Control
Type
1
Secret menu No. E15:
See the Controlling Type for details
Note: This parameter does not change after factory settings are restored. To be more compatible with gateways, after setting this parameter, please add in the gateway again.
12 0-12
26 Changeover
Valve Logic
1 Secret menu No. E16: 0=When the heat pump
starts heating, O/B turns off 1=When the heat
0 0-1
27 Compressor
Protection Time
1 Secret menu No. E17: The setting of compressor
1 0-10
28 EM (AUX)
Emergency Heat
Mode
1 Secret menu No. E18: 1: ON 0: OFF Note: This mode
function
0 0-1
29 Time Display
Selection
1 When Schedule function is activated: 0: Time,
week, current time period displays. 1: Week and
current time period displays. 2: Time, week and
0 0-2
30 Fan Shutdown
Delay Time
1 This parameter is valid only when the fan mode is
down, unit: minute
0 0-127
31 Compressor          delay countdown display 1
0: No Display
1: Display
0 0-1
32 Whether to enable electrical auxiliary heat 1
0: Disable
1: Enable
1 0-1
45 Schedule
Function
Selection
1 0: Disabled 1: Enabled 0 0-1
46 The 1st period
from Mon-Sun
2 Byte1(MSB): Minute Byte2(LSB): Hour Byte1: 0
Byte2: 6
Byte1: 0-59
Byte2: 0-23
47 The 2nd period
from Mon-Sun
Byte2: 8
Byte1: 0-59
Byte2: 0-23
48 The 3nd period
from Mon-Sun
Byte2: 18
Byte1: 0-59
Byte2: 0-23
49 The 4nd period
from Mon-Sun
Byte2: 22
Byte1: 0-59
Byte2: 0-23
50 Heat SetPoint for 1st period from Mon-Sun 2 n*0.1 Celsius or n*0.1 Fahrenheit Celsius:210 Fahrenheit: 700 The range is greater than the lower limit and smaller than the upper limit
51 Heat SetPoint for
2nd period from
Mon-Sun
2 n*0.1 Celsius or n*0.1 Fahrenheit Celsius:165
Fahrenheit: 620
upper limit
52 Heat SetPoint for
3rd period from
Mon-Sun
2 n*0.1 Celsius or n*0.1 Fahrenheit Celsius: 210
Fahrenheit: 700
upper limit
53 Heat SetPoint for
4th period from
Mon-Sun
2 n*0.1 Celsius or n*0.1 Fahrenheit Celsius: 165
Fahrenheit: 620
upper limit
54 Cool SetPoint for
1st period from
Mon-Sun
2 n*0.1 Celsius or n*0.1 Fahrenheit Celsius: 255
Fahrenheit: 780
upper limit
55 Cool SetPoint for
2nd period from
Mon-Sun
2 n*0.1 Celsius or n*0.1 Fahrenheit n*0.1 Celsius or n*0.1 Fahrenheit The range is greater than the
upper limit
56 Cool SetPoint for
3rd period from
Mon-Sun
Fahrenheit: 780
upper limit
57 Cool SetPoint for
4th period from
Mon-Sun
2 n*0.1 Celsius or n*0.1 Fahrenheit Celsius: 280
Fahrenheit: 820
upper limit
58-64 The 1st period for
Mon...Sun
Byte2(LSB): Hour
Byte1: 0
Byte2: 6
Byte1: 0-59
Byte: 0-23
65-71 The 2nd period
for Mon...Sun
Byte2(LSB): Hour
Byte1: 0
Byte2: 8
Byte1: 0-59
Byte: 0-23
72-78 The 3rd period for Mon...Sun 2 Byte1(MSB): Minute Byte2(LSB): Hour Byte1: 0
Byte2: 18
Byte1: 0-59
Byte: 0-23
79-85 The 4th period
for Mon...Sun
Byte2(LSB): Hour
Byte1: 0
Byte2: 22
Byte1: 0-59
Byte: 0-23
86-92 The 1st heat
SetPoint for
Mon...Sun
Fahrenheit: 700
upper limit
93-99 The 2nd heat
SetPoint for
Mon...Sun
Fahrenheit: 620
upper limit
100-
106
The 3rd heat
SetPoint for
Mon...Sun
Fahrenheit: 700
upper limit
107-
113
The 4th heat
SetPoint for
Mon...Sun
Fahrenheit: 620
upper limit
114-
120
The 1st cool
SetPoint for
Mon...Sun
Fahrenheit: 780
upper limit
121-
127
The 2nd cool
SetPoint for
Mon...Sun
2 n*0.1 Celsius or n*0.1 Fahrenheit Celsius: 295
Fahrenheit: 850
upper limit
128-
134
The 3rd cool
SetPoint for
Mon...Sun
Fahrenheit: 780
upper limit
135-
141
The 4th cool
SetPoint for
Mon...Sun
Fahrenheit: 820
upper limit
255 Factory Restore 1 1: Restore factory setting 0: Invalid 0 0-1
Regulatory Information FCC Information
This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) this device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. Note: This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This product generates, uses, and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment o and on, the user is encouraged to try to correct the interference by one or more of the following measures: Reorient or relocate the receiving antenna. Increase the separation between the equipment and receiver. Connect the equipment to an outlet on a circuit different from that to which the receiver is connected.
Consult the dealer or an experienced radio/TV technician for help. Please take attention that changes or modification not expressly approved by Ezlo Innovation could void the user’s authority to operate the equipment. This equipment should be installed and operated with a minimum distance 20cm between the radiator and your body. Industry Canada ICES-003 Compliance This device meets the CAN ICES-3 (B)/NMB-3(B) standards requirements. This device complies with Industry Canada licence-exempt RSS standard(s). Operation is subject to the following two conditions: (1) this device may not cause interference, and (2) this device must accept any interference, including interference that may cause undesired operation of the device. Under Industry Canada regulations, this radio transmitter may only operate using and antenna of a type and maximum (or lesser) gain approved for the transmitter by Industry Canada. To reduce potential radio interference to other users, the antenna type and its gain should be so chosen that the equivalent isotropically radiated power (e.i.r.p.) is not more than that necessary for successful Communication.
This equipment complies with IC RSS-102 radiation exposure limits set forth for an uncontrolled environment. This equipment should be installed and operated with minimum distance 20cm between the radiator & your body.
1-Year Limited Warranty
We warrant this product to be free from defects in material and workmanship under normal and proper use for one year from purchase date of the original purchaser. We will, at its option, either repair or replace any part of its products that prove defective by reason of improper workmanship or materials. This limited warranty does not cover any damage to this product that results from improper installation, accident, abuse, misuse, natural disaster, insufficient or excessive electrical supply, abnormal mechanical or environmental conditions, or any unauthorized disassembly, repair or modification. This limited warranty shall not apply if: (i) the product was not used in accordance with any accompanying instructions, or (ii) the product was not used for its intended function. This limited warranty also does not apply to any product on which the original identification information has been altered, obliterated or removed, that has not been handled or packaged correctly, that has been sold as second-hand or that has been resold contrary to Country and other applicable export regulations.
You’re now ready to enjoy smarter
home control.
You can also download the Installation Manual here
Was this article helpful?
1 out of 1 found this helpful
Comments
0 comments
