How to reset Ezlo Plus & LED Behavior
Sara
Sara
  • Updated
Reset Button
Reset button action Result action
1 short (0.05 - 0,5 seconds) press within 1 .5 second Send the broadcast message to cloud server
2 short (0.05 - 0,5 seconds) presses within 1.5 second Reset client connection Wi-Fi settings
3 short (0.05 - 0,5 seconds) presses within 1.5 second Perform hub Power off action
One long (2 - 5 seconds) press Reboot controller
One long (5 - 10 seconds) press Soft reset
One long (10 - 20 seconds) press Factory reset
Holding more than 20 seconds Cancel factory reset start
Reset logic
Actions to be performed on both reset type are summarized in the table below
Hub element
Soft reset
Reset to factory defaults
Included devices Remove from hub, left in included state Remove from hub, left in included state
ZWave network ID Change to random value Change to random value
WiFi settings Doesn’t change Restore to defaults
Backups stored at controller Doesn’t change Remove
Plugins data Remove Remove
Other user data Remove Remove
User addons and plugins Don't change Remove
Default addons and plugins Don't change Restore to defaults
LED behavior
  Led Status Solution
The hub is powering on mceclip0.png Wait for it to boot
The hub has encountered an error while powering on mceclip2.png Soft reset the hub
The hub is upgrading the firmware mceclip3.png Wait for the hub to finish and LED Status to turn steady blue
The hub is in pairing mode mceclip4.png mceclip5.png See specific device pairing instructions
The hub has detected the paired device mceclip4.png mceclip6.png Check your app or dashboard to see and control your device
The hub cannot connect to Internet mceclip7.png Check wireless or wired connectivity
Was this article helpful?
2 out of 11 found this helpful
Comments
0 comments
