Ezlo Atom LED Behavior
Sara
Sara
  • Updated
Reset button action
Result action
LED Indication
Z-Wave action
NA Atom is not connected to the router 1 blink per second, until Atom will be connected to Wi-Fi
NA Atom is connected to the router but doesn't connected to the server 1 blink per 3 seconds, until Atom will be connected to the server
NA Atom is connected to the server NO blinks
NA Atom is in inclusion mode, interview is NOT started LED is On
NA Atom is in inclusion mode, interview is started 10 blinks per second, stop when interview process will be finished
NA Atom is in exclusion mode, interview is NOT started LED is On
NA Atom is in exclusion mode, interview is started 10 blinks per second, stop when interview process will be finished
Connect the Ezlo Atom to the power supply with the button pressed down Test mode 3 blinks per second
One short (0.2 - 2,5 seconds) pressing Send the broadcast message to NMA server 1 blink Broadcast HAIL message
Two short (0.2 - 2,5 seconds) pressings Reset to default options of a local WiFi connection of an Atom32 hub
  • 3 blinks per second, stop when reset process will be finished
  • Once finished - 1 blink per second, until Atom will be connected to Wi-Fi
One long (5 - 9.5 seconds) pressing Soft reset (remove all devices, reset settings, hub remains connected to Wi-Fi LAN)
  • 10 blinks per second, stop when reset process will be finished
  • Start blinking after 5th second of button pressed
One long (more than 10 seconds) pressing Factory reset
  • LED is On, turn Off when reset process will be finished
  • Turn On LED after 10th second of button pressed
Was this article helpful?
0 out of 0 found this helpful
Comments
0 comments
