This article demonstrates how easy it is to pair Evolve Dual Outlet with Ezlo hubs.
Pairing
Have the controller and device close to one another.
- Step 1: Open the “Devices” menu on the app, then click the “+” icon.
- Step 2: Scroll down and select “Generic Z wave device.”
- Step 3: Tap “Next.”
- Step 4: Select “Add Device.”
- Step 5: Press and hold down the switch button on your Evolve Dual Outlet Receptacle.
- Step 6: The controller will recognize the device.
- Step 7: Select the added device on the app to complete the pairing.
Wall Outlet
Plug in the device you want to use or control.
Use the device to switch the lamp on and off.
You can now confirm that your Evolve Dual Outlet works well with Ezlo hubs.
Unpairing
On your app, select the “Unpair” icon.
Go to the device and press down the switch.
When the app registers the action, tap “Ok” to confirm.
Comments
0 comments
