How to Pair Honeywell Plug-in Dimmer 39336 ZW3104
Sara
Sara
  • Updated
Follow the below steps for a seamless pairing of your Honeywell Plug-in Dimmer with the Ezlo Hubs.
Pairing
Plug in your dimmer into an electrical socket.
  • Step 1: On the main menu, select “Devices.”
  • Step 2: Tap the “+” symbol.
  • Step 3: The device wizard will display a list of devices.
  • Step 4: Choose your device.
  • Step 5: Tap “Add Device.”
  • Step 6: Click “Continue” and go to the dimmer.
  • Step 7: Press down the pairing button for a few seconds.
  • Step 8: Wait for the devices to recognize each other.
  • Step 9: On the app, tap on the Honeywell Plug-in Dimmer to confirm pairing.
Smart Dimmer
On successful pairing, you can plug in the device you want to control and create scenes to confirm that your device works with Ezlo.
Use the app to switch on and off the dimmer and vary light intensities.
Unpairing
Select the “Unpairing” icon on the app.
Press and hold down the action button of your dimmer.
On the app, confirm by tapping “Ok.”
Was this article helpful?
0 out of 0 found this helpful
Comments
0 comments
