This article shows how easy it is to pair your fan controller with Ezlo Hubs.
Pairing
- Step 1: Open “Devices” in your Vera app.
- Step 2: Click the “+” symbol to add devices.
- Step 3: Select your device from the scroll-down menu and tap “Add New Device.”
- Step 4: Press “Continue” to activate the “Device wizard.”
- Step 5: Tap “Next” and go to the controller.
- Step 6: Press the inclusion button twice on the controller while keeping it close to your smartphone.
- Step 7: On your app, tap “Continue” when it recognizes the device.
- Step 8: The app will ask for a 5-digit code.
- Step 9: You will find the code on the device.
- Step 10: Tap “Continue,” and enter the five-digit code.
- Step 11: Then tap “Next.”
- Step 12: Wait for them to pair, then press “Done.”
Fan Controller
Your fan controller now features in the list of devices, and you can start using it.
Connect the device you want to control and start creating scenes.
The HomeSeer Fan Controllers, like the HS-FC200+, work harmoniously with the Ezlo Hubs.
Unpairing
Tap the “Unpair button.”
Press the device once, and tap “Ok” to confirm when the unpair registers.
Unpairing success.
Comments
0 comments
