How to Pair GE Jasco Plug-in Outdoor Switch ZW4201 14284
Sara
Sara
  • Updated
You can easily pair the GE Jasco Plug-in Outdoor Switch ZW4201 14284 with Ezlo by following the steps below:
Pairing
  • Step 1: Select “Devices” on the main menu of your app.
  • Step 2: Click the “+” symbol.
  • Step 3: Click “Add device” and confirm pairing by hitting “Next.”
  • Step 4: Find “GE Jasco Plug-in Outdoor Switch”, and tap on it to start pairing.
  • Step 5: Go to the GE Jasco Plug-in Outdoor Switch and press the pair button.
  • Step 6: Once the controller recognizes it, it will pair and displays it on the app.
  • Step 7: Confirm the successful pairing by clicking “Save.”
  • Step 8: Congratulations. You can create a room and name it.
Using the Smart Switch
Open the cover and plug in the device you want to control.
The switch controls lights, fans, and other appliances.
Now use your smartphone to switch on and off the light.
Congratulations, your device works with Ezlo.
Unpairing
Go to the “Unpair” icon on the app.
Go to the device and press the action button.
Go to the app to confirm this action by tapping “Ok.”
Was this article helpful?
0 out of 2 found this helpful
Comments
0 comments
