Pairing
- Step 1: First, open “Settings” in your app and select “Devices.”
- Step 2: Then, tap the “+” icon on the screen’s top right.
- Step 3: You will find a list of devices.
- Step 4: Select and tap Leviton White Ivory Light Almond.
- Step 5: Next, click “Add device, then “Next.”
- Step 6: Go to your device and press the pairing button.
- Step 7: The indicator light on the front of the device will blink to confirm pairing.
- Step 8: When the app recognizes the device, confirm the pairing.
- Step 9: Congratulations, you have successfully paired your devices.
Using the Device
Plug in the device you want to control.
Now use the app on your smartphone to control the light and set scenes.
The Leviton White Ivory Light works with Ezlo.
Unpairing
Tap on the “Unpair” icon on the app.
Press twice on the action button of your device.
The indicator light will light momentarily.
Go back to the app to confirm and tap “Ok.”
Unpairing successful.
Comments
0 comments
