Below is an easy process of pairing your Satco In-Wall Switch 86-102 with Ezlo Hubs.
Pairing
- Step 1: On the Vera app, under settings, select “Devices.”
- Step 2: Click on the “+” sign at the top right corner.
- Step 3: Go to “Pair New Device.”
- Step 4: Then, tap on “Next.”
- Step 5: Go to the “Satco In-Wall Switch,” then press and hold the switch.
- Step 6: The pairing process begins, and the controller identifies the device.
- Step 7: Go to the app and select “Satco In-Wall Switch 86-102” from the list of available switches.
- Step 8: You have successfully paired the devices.
Using the Light Switch
Connect your In-Wall Switch to the device you want to control and play out scenes using the Ezlo app.
You can now switch on and off the light bulb using the app.
Do the same for the Satco In-Wall Switch as a confirmation that your device works with Ezlo. Congratulations.
Unpairing
On the app, click the “Unpair” icon.
Go to the device and press the switch.
Go back to the app and tap “Ok” to confirm.
Comments
0 comments
