The installation of Jasco Dimmer Switch 45742-1 is simple and doesn’t need any technical knowledge. You can connect the hub to the light switch using the plug-and-play cable.
Pairing
- Step 1: Open the Ezlo app and select “Devices” from the main menu.
- Step 2: Tap the “+” sign on the top right corner.
- Step 3: Locate “Jasco Dimmer Switch 45742-1” and tap on it.
- Step 4: Then, click “Add Device.”
- Step 5: Click “Next” to begin pairing.
- Step 6: Go to your Jasco Dimmer Switch and press the pair button.
- Step 7: Confirm pairing on the app once it recognizes your device.
- Step 8: You have successfully paired the devices.
Using the Dimmer Switch
Now confirm the pairing by controlling and creating scenes with the app.
Go to “Light module” on the app to switch on the dimmer.
Vary light intensity using the app and watch how it plays out.
Next, use the dimmer to create scenes.
Congratulations, Jasco Dimmer Switch works with Ezlo.
Unpairing
Locate and tap the “Unpair” icon.
Go to the dimmer and push the pairing button.
Confirm unpairing by tapping “Ok” on the app.
- mceclip0.jpg30 KB
Comments
0 comments
