You can easily pair the UltraPro In-Wall Dimmer 39351 with Ezlo by following the steps below:
Pairing
- Open the Ezlo app on your smartphone or tablet and go to “Settings.”
- Select “Devices” and tap on the “+” symbol at the top right corner.
- From the “Available Devices” that appears on the screen, select “UltraPro In-Wall Dimmer 39351”.
- Next, press ‘Add.’
- Click ‘Next,’ and the pairing process will begin.
- Go to the dimmer and press twice on the switch.
- Your new device will now appear on your app.
- Select the device and tap “Continue.”
- It will request the 5-digit number appearing on your device.
- Press “Next” and input the 5-digits.
- Tap “Save.”
- The message “Device Successfully Added” appears on-screen.
- Confirm by tapping “Done.”
Smart Dimmer
Connect the device you want to control, and you can now vary the brightness using the app.
Create scenes of varying intensity levels.
You can now confirm that UltraPro In-Wall Dimmer 39351 works with Ezlo hubs.
Unpairing
Click the “Unpair” icon.
Press twice on the dimmer switch.
Confirm unpairing by tapping “Ok” on the app.
Comments
0 comments
