How to Pair Satco In-Wall Dimmer 86-103
Sara
Sara
  • Updated
Pairing the Satco In-Wall Dimmer 86-103 with the Ezlo Hubs is easy to execute. Below is a step-by-step guide.
Pairing
  • Step 1: Go to “Devices” in the Vera app and tap the “+” symbol.
  • Step 2: Select “Add Device,” which will take you to a list of available devices.
  • Step 3: Select In-Wall Dimmer and hit “Pair Device.”
  • Step 4: Tap “Next” to commence pairing.
  • Step 5: Go to the Satco In-WallDimmer and press the switch twice.
  • Step 6: The device will start pairing, and the controller will recognize it.
  • Step 7: Complete the process by tapping “Save” and start using the Vera app to control it.
Using the Dimmer
You can now use your app to create scenes by dimming lights or setting them to specific brightness levels. You can confirm that the Satco In-Wall Dimmer 86-103 works with Ezlo.
Unpairing
Go to the Vera app and select the “Unpair” icon.
On the dimmer, press twice on the switch,
Go to the app and confirm the action by tapping “Ok.”
Your devices are now unpaired.
Was this article helpful?
0 out of 0 found this helpful
Comments
0 comments
