How to Pair 2GIG Panic Button Remote 2GIG PANIC1-345
Sara
Sara
  • Updated
Follow the below easy steps for setting up 2GIG Panic Button Remote with Ezlo Hubs.
Pairing
  • Step 1: Go to the “Devices” menu on your app.
  • Step 2: Tap the “+” to add a new device.
  • Step 3: The “Device Wizard” will display available devices.
  • Step 4: Select “Hand Held.”
  • Step 5: Tap the “Search” icon to search for your Panic Button.
  • Step 6: Select “2GIG Panic Button Remote” from the list of available devices.
  • Step 7: Tap “Next” to start the pairing process.
  • Step 8: Use your phone’s camera to scan the QR code on the back of the Panic Button or add it manually by inputting the code available on the packaging.
  • Step 9: Click “Next” and confirm having added all your devices by tapping ”Done.”
  • Step 10: You have successfully paired your device with the Ezlo Hubs.
Now you can create scenes
  • Under devices, select “Panic Button” and select “Scenes” from the list.
  • Click the “+” symbol to create a scene.
  • Select “Add Event” and tap “Add a Device.”
  • Then, click again “Panic Button.”
  • Choose a device trigger by tapping “The button is being held.”
  • Click “Done.”
  • Next, tap “Add Action.”
  • Next, go to “Device Action.”
  • Select “Plug-in Switch” and click “On.”
  • Tap “Done,” then “Save” scene, and name your new scene.
  • Save the name.
  • Next, go back to the “Devices” menu.
  • Press and hold down the Panic Button Remote while keeping an eye on the app.
  • The Plug-in switch will go “On.”
  • You have now successfully paired the Remote Panic Button with Ezlo.
Unpairing
On the “Devices” screen, tap on the “Panic Button.”
On the bottom of the screen, click “Unpair.”
Confirm the successful unpairing action.
Was this article helpful?
0 out of 0 found this helpful
Comments
0 comments
