Follow the below easy process of pairing zooZ Dimmer ZEN22 VER 4.0 with Ezlo.
Pairing
- Step 1: On your app’s “Devices” menu, tap the “+.”
- Step 2: The “Device Wizard” will display available devices.
- Step 3: Select “Generic Z Wave Devices” and tap “Next.”
- Step 4: Tap “Add a New Device.”
- Step 5: Click “Next” to initiate the pairing process.
- Step 6: Go to the Dimmer, and press the switch.
- Step 7: The Controller will detect the device and start pairing.
- Step 8: Select “Connection Security” on the Ezlo app and click “Continue.”
- Step 9: Wait for pairing confirmation and click “Save.”
- Step 10: You have successfully paired your zooZ Dimmer with Ezlo Hubs.
You now control your lights from anywhere, using the dimmer or app. You can also create scenes and vary the brightness of your lights by pressing down your Dimmer until you achieve the required brightness level.
Unpairing
Click the “Unpair” icon under the “Devices” menu.
Long press the Dimmer switch and confirm unpairing,
Click “Ok” to finalize.
- mceclip0.jpg60 KB
Comments
0 comments
