How to Pair GE Jasco In-Wall Smart Dimmer 14294 ZW3005
Sara
Sara
  • Updated
The following process outlines the pairing process of the GE Jasco In-Wall Smart Dimmer 14294 ZW3005 with Ezlo Hubs.
Pairing
  • Step 1: Connect your Smart Dimmer and keep it close to the Controller.
  • Step 2: Tap the “+” on the Ezlo app to open the “Device Wizard.”
  • Step 3: Select your device by tapping on the “Generic Z Wave Devices.”
  • Step 4: Click “Next” to commence the pairing process.
  • Step 5: On the Smart Dimmer, press the switch.
  • Step 6: The Controller will detect the device and start pairing.
  • Step 7: Select “Add New Devices” on the Ezlo app and name it.
You have successfully paired your GE Jasco In-Wall Smart Dimmer 14294 ZW3005 with Ezlo Hubs.
Now create scenes with your device and monitor through the app. You can also remotely control the dimmer with your app.
Unpairing
Tap the “Unpair” symbol on your app.
Press and hold the Smart Dimmer’s switch.
Tap on “Ok” to confirm your action.
Was this article helpful?
0 out of 2 found this helpful
Comments
0 comments
