This step-by-step tutorial shows the pairing process of the GE Jasco In-Wall Smart Switch 46202 ZW4009 with Ezlo Hubs.
Pairing
- Step 1: Connect your smart switch to your wall outlet.
- Step 2:On the Ezlo app, tap the “+” icon.
- Step 3: Scroll down to “Generic Z Wave Devices” and tap on it.
- Step 4: Select “Add Device” and confirm the pairing process for it to start.
- Step 5: On the Smart switch, press the action button once by sliding it up.
- Step 6: Once the devices connect, tap “Continue” on the app.
- Step 7: Under “Advanced Options,” select the Jasco In-Wall Smart Switch, then press “Continue.”
- Step 8: Next, get the 5-digit code on the device or from its packaging.
- Step 9: Press “Next” and input the five-digit code.
- Step 10: Tap “Ok” to commence the pairing process.
- Step 11: Tap “Done” to confirm successful pairing.
Once connected, you can control your lights from anywhere and automatically set timers for them to turn on/off at certain times of the day.
Unpairing
On your app, tap the “Unpair” symbol.
Hold down the switch on the Smart Switch.
Tap on “Ok” in the app to confirm the successful unpairing process.
Comments
0 comments
