How to Pair Kwikset SmartCode Touchpad Electronic Deadbolt 912
Sara
Sara
  • Updated
Pairing
  • Step 1: Ensure the device is in pairing mode and the light is flashing red.
  • Step 2: Place it close to the controller.
  • Step 3: On the main menu of the app, choose “Devices.”
  • Step 4: Tap the “+” sign.
  • Step 5: Next, select “Add New Device.”
  • Step 6: Then, go to the “Door Locks” category.
  • Step 7: Select and tap on “Kwikset SmartCode Touchpad Electronic Deadbolt 912” from the list.
  • Step 8: Hit “Next” to initiate the pairing.
  • Step 9: Go back to your device and open the back cover by sliding it upwards.
  • Step 10: Press the button on the device two times to start pairing.
  • Step 11: Tap “Next” on the device to confirm.
  • Step 12: The controller will confirm the pairing process.
  • Step 13: Click “Done” after pairing successfully.
Deadbolt
  • You can use the app to lock and unlock your door.
  • You will need to set a password on the keypad.
  • Press on the side of the “Lock Button.”
  • Go to “Add New PIN Code”
  • On the app, input the 4-digit code and confirm.
  • Go to your device, and on the touchpad, input the PIN.
  • Confirm on the app if it locks the door.
  • If it does, you have successfully paired the devices.
  • You can now program the keypad to match the code of your house.
Unpairing
Open the Ezlo app and select the “Unpair a device” icon.
Select your Kwikset SmartCode Touchpad Electronic Deadbolt 912 from the list.
Go to the device and press the button.
On the app, confirm your action by tapping “Ok.”
Was this article helpful?
0 out of 0 found this helpful
Comments
0 comments
