How to Pair GoControl Smart Dimmer Switch MP22Z
Sara
Sara
  • Updated
The GoControl Smart Dimmer Switch MP22Z is the perfect addition to a home automation system compatible with the Ezlo app. This guide explores how to pair your GoControl Smart Dimmer Switch MP22Z with Ezlo Hubs.
Pairing
Plug the GoControl Smart Dimmer Switch MP22Z into an outlet in any room you would like to control with your Ezlo Hub.
Remove the battery protector at the back of the switch and connect the dimmer to an intelligent bulb or dimmer.
  • Step 1: Open the Ezlo app and tap on the “Devices” icon.
  • Step 2: Select “Add Device” at the top right corner of your screen by tapping the “+” symbol.
  • Step 3: Select “Dimmers and Lights” to get available devices.
  • Step 4: Choose “GoControl Smart Dimmer Switch MP22Z” from the list of available devices.
  • Step 5: Go to your device and press the button at the back of the GoControl Smart Dimmer Switch MP22Z.
  • Step 6: The unit will begin pairing with your mobile device and switch on the smart bulb.
  • Step 7: The controller will find and automatically connect with the device.
  • Step 8: Press “Next” to confirm the pairing success.
Dimmer
Once the Hub finds your dimmer switch, the pairing is successful.
You may now set scenes and control the lights using your app.
Unpairing
On your app, select “Unpair Device.”
Press “Next.”
Press the back button of your dimmer to start the process.
Go back to the app and confirm your action.
Was this article helpful?
0 out of 0 found this helpful
Comments
0 comments
