This guide outlines a straightforward process for setting up and pairing your Dome Door / Window Sensor DMDP2 with your Ezlo controller.
- Keep your devices close to each other for seamless pairing.
- On the MiOS app, go to More > Devices, tap the “+” symbol, select the controller where you want to add the device, and then go to “Sensors” to get a list of available devices.
- Find and select “Dome Door / Window Sensor DMDP2”.
- Tap "Next" and follow the wizard instructions.
- Go to your sensor and open the back cover to reveal the button.
- Press the button twice.
- It will flash a red light for a few seconds and stop.
- The controller will pick out your sensor and pairs.
- Wait for the confirmation on your MiOS app and name your device.
Congratulations!
Your sensor pairing is complete, and you can create MeshBots by moving close to the two parts of the sensor.
Comments
0 comments
