This guide outlines a straightforward process for pairing your Inovelli Dimmer Switch LZW31 with your Ezlo controller.
- Plug your Dimmer Switch LZW31 into an outlet and turn on the power.
- Set up your dimmer switch, and controller close to each other.
- On the MiOS app, go to More > Devices, tap the “+” symbol, select the controller where you want to add the device, then go to "Generic Z-Wave device“ and tap "Next".
- Tap “Next” again to start the pairing.
- Go to your sensor and press the top button of your Inovelli Dimmer Switch LZW31 three times.
- Go to the app and confirm the pairing process.
- Tap “Continue” when prompted by the app to allow access enter the 5-digit SDK code on the dimmer’s back cover and tap "Continue" again.
- Wait for the confirmation on your MiOS app and name your device.
Congratulations.
You can now use your MiOS app to control the dimmer and set Meshbots on varying light intensities.
Comments
0 comments
