This guide outlines a straightforward process for pairing a GoControl plug-in dimmer with your Ezlo controller.
- To begin, keep the pairing devices close to each other.
- Plug your dimmer onto a wall socket.
- On the MiOS app, go to More > Devices, tap the “+” symbol, select the controller where you want to add the device, then go to "Dimmers and lights" and select GoControl Plug-in Dimmer and tap “Next”.
- Tap on “Next” to initiate pairing.
- Return to the dimmer, and press the action button to start pairing.
- Wait for the confirmation on your MiOS app and name your device.
Congratulations.
You can now use your MiOS app to control the dimmer and set Meshbots on varying light intensities.
Comments
0 comments
