This guide outlines a straightforward process for pairing your Fibaro Dimmer 2 with your Ezlo controller.
- To begin, ensure the dimmer and the dimmer lamp are positioned close to the controller.
- On the MiOS app, go to More > Devices, tap the “+” symbol, select the controller where you want to add the device, then go to “Dimmers and Lights”, search for Fibaro Dimmer 2 FGD-212 v3.5 and select it.
- Once the Fibaro Dimmer is ready for pairing, tap “Next” to initiate the pairing process.
- Press the action button with a small screwdriver or pin to activate pairing mode on your Dimmer.
- Wait for the controller to identify and pair with the dimmer.
When prompted, confirm the pairing, and name your device.
Congratulations.
You can now use your MiOS app to control the dimmer and set Meshbots on varying light intensities.
Comments
0 comments
