This guide outlines a straightforward process for pairing your Enbrighten In-Wall Smart Switch ZW39 with your Ezlo controller.
- To begin, install the new faceplate onto your existing switch and align it with the electrical box.
- On the MiOS app, go to More > Devices, tap the “+” symbol, select the controller where you want to add the device, then go to “Lighting” from the dropdown menu and choose your Enbrighten In-Wall Smart Switch ZW39 from the list of available devices.
- Go to the Enbrighten In-Wall Smart Switch ZW39 and tap the top paddle just once.
- Enter your Smart Switch 5-digit SDK code and click “Pair Device” when prompted.
Once paired, you can use the MiOS app to control your Enbrighten In-Wall Smart Switch ZW39 from anywhere.
Comments
0 comments
