This guide outlines a straightforward process for pairing the Enbrighten ZW3006 In-Wall Dimmer with your Ezlo controller, allowing compatibility with most dimmable LED or CFL bulbs.
- On the MiOS app, go to More > Devices, tap the “+” symbol, select the controller where you want to add the device, and then go to “Dimmers and lights” and select "GE/Jasco In-Wall Dimmer" from the list of available devices.
- Tap on the “Next”. The app will commence pairing your device with your Ezlo controller.
- On the Enbrighten ZW3006 In-Wall Dimmer, press the action button once to initiate pairing.
- Complete the pairing process, and you can start using the MiOS app to control the dimmer.
Congratulations!
Your MiOS app can now switch on and off the dimmer lights.
Furthermore, you can adjust the light intensity from 1 to 100% using the MiOS app, enabling customized dimming capabilities.
Comments
0 comments
