This guide outlines a straightforward process for pairing the Zooz Outdoor Motion Sensor ZSE29 with your Ezlo controller, ensuring seamless integration into your smart home system.
- To begin, maintain proximity between the controller and the sensor throughout the pairing process.
- First, remove the battery tab from the back of the sensor to reveal the inclusion button and check the battery status.
- On the MiOS app, go to More > Devices, tap the “+” symbol, select the controller where you want to add the device, and then go to "Sensors" and select the "Zooz Motion Sensor ZSE29".
- Press “Next” to begin pairing the devices.
- Back to the motion sensor, press the inclusion button on your Zooz Motion Sensor ZSE29 until it’s in pairing mode.
- On the MiOS app, confirm the pairing by entering the 5-digit SDK code, which you will find inside the sensor’s back cover.
- Click “Next” to finalize the process.
Congratulations. You have successfully set up your Zooz Motion Sensor.
Test its functionality by waving your hand across the sensor to ensure it triggers your MeshBots.
Comments
0 comments
