How to Pair an Evolve Plug-in Appliance Module LPM-15
Sara
Sara
  • Updated
This guide outlines a straightforward process for pairing an Evolve Plug-in Appliance Module LPM-15 with your Ezlo controller, a task that can be completed in just a few minutes.
  • To begin, find a suitable location to plug in the Evolve Plug-in Appliance Module LPM-15 and securely insert it into a wall outlet.
  • On the MiOS app, go to More > Devices, tap the “+” symbol, select the controller where you want to add the device, then go to Select “Dimmers & Lights” and look for the Appliance Module.
  • Tap on the Appliance Module to activate pairing.
  • When you're ready, tap “Next,” and the pairing process will begin.
  • Return to the Module and press the action button twice while keeping it close to the controller.
  • Your Ezlo controller will connect and pair up with the Plug-in Appliance Module.
Congratulations!
You're now all set to go. You can plug any appliance into your Evolve Plug-in Appliance Module LPM-15 and control it with the MiOS app. Use the MiOS app to switch appliances on or off, or even control lights as needed.
How to pair an Evolve Plug-in Appliance Module LPM-15 with Ezlo Hubs? -  YouTube
Was this article helpful?
0 out of 2 found this helpful
Comments
0 comments
