This guide outlines a straightforward process for pairing your Fibaro Smoke Sensor with your Ezlo controller.
- On the MiOS app, go to More > Devices, tap the “+” symbol, select the controller where you want to add the device, then go to Select your sensor and click on it.
- When ready, click “Next” to initiate the pairing process.
- Now, on the sensor, remove the plastic backplate to access the battery pull tab. Press the Test button three times while keeping the smoke sensor close to your Ezlo controller.
- Once the Controller recognizes the smoke sensor, it will start pairing it with your system.
- Return to the MiOS app to choose a name for your smoke sensor and assign it to a room to finalize the setup process.
Congratulations!
You have now successfully added extra convenience and protection to your home with the Fibaro Smoke Sensor and the MiOS App.
Comments
0 comments
