This guide outlines a straightforward process for pairing your Aeotec Door Window Sensor 6 with your Ezlo controller.
- To begin, ensure your sensor is near the controller for effective pairing.
- Open the plastic backplate and insert the provided Micro USB cable to charge it.
- On the MiOS app, go to More > Devices, tap the “+” symbol, select the controller where you want to add the device, then go to “Sensors,” and look for Aeotec Door Window Sensor 6 to select it.
- Once the Aeotec Door Window Sensor 6 is ready, tap “Next” to initiate the pairing process while keeping the sensor close to the controller.
- On the Door Window Sensor, press the action button once. As a confirmation, the onboard LED will blink for two seconds before turning solid.
- Once your Ezlo controller recognizes the device, it will pair it with your system.
- Return to the MiOS app, where you can name your sensor, assign it to a room, and complete the setup process.
Congratulations!
You can now monitor the sensor and trigger MeshBots using the MiOS app.
Comments
0 comments
