This guide presents a straightforward process for pairing your Aeotec Smart Dimmer 6 with your Ezlo controller.
- To begin, prepare the location where you intend to place your Smart Dimmer and plug it into a wall socket.
- On the MiOS app, go to More > Devices, tap the “+” symbol, select the controller where you want to add the device, then go to “Dimmers and Lights” and look for Smart Dimmer 6 and click on it to start the pairing wizard.
- When the dimmer is ready for pairing, hit “Next” to initiate the pairing process.
- Return to your Smart Dimmer and press the action button twice.
- Your Ezlo controller will then detect and pair with the dimmer.
- Return to the MiOS app, where you can choose a name for your Smart Dimmer, assign it to a room, and finalize the setup.
Congratulations!
You're all set to use your MiOS app to control and adjust your lights from anywhere.
Comments
0 comments
