This guide presents a straightforward process for pairing your Zooz 4-in-1 Sensor with your Ezlo controller.
- Begin by opening the plastic cover of your Zooz 4-in-1 Sensor to insert the battery.
- On the MiOS app, go to More > Devices, tap the “+” symbol, select the controller where you want to add the sensor, then go to “Sensors,” look for “zooZ 4-in-1 Sensor” and select it.
- When ready, press “Next” to commence the pairing process.
On the Zooz 4-in-1 Sensor, use a paper clip to press the Z-Wave pairing button twice, and the onboard LED will blink twice to confirm it’s working.
- Ensure the Sensor is near the controller throughout this process.
- Your Ezlo controller will recognize the Sensor and pair it with your system.
- In the MiOS app, choose the name for the Sensor and choose a room to finalize the process.
Congratulations.
Your motion sensor is now working, and you can monitor or use it to trigger a MeshBot in your MiOS app.
Comments
0 comments
