This guide outlines the setup and pairing process for the Schlage Connect Smart Deadbolt BE469ZP with Ezlo. During the process, ensure the Deadbolt is close to your Ezlo controller.
Follow these steps:
- First, unpack your Schlage Connect Smart Deadbolt BE469ZP, confirm the key and the programming code are present, and have it close to your Ezlo controller for a fast pairing process.
- Codes are located on the sticker on the back of the deadbolt guide and at the back of the interior escutcheon.
- Open the door and extend the deadbolt before beginning.
- On the MiOS app, go to More > Devices, tap the “+” symbol, select the controller where you want to add the deadbolt, then go to "Door Locks" and choose “Schlage Connect Smart Deadbolt BE469ZP”.
- Tap “Next.” and you will see a countdown.
- On the “Schlage Connect Smart Deadbolt BE469ZP”, press the Schlage button, enter the 6-digit programming code, and press the 0 key, it will flash yellow, then green to confirm successful addition.
- Tap “Continue” when prompted by the app to allow access enter the 5-digit SDK code on the Schlage and tap "Continue" again.
- Your Ezlo controller will confirm the pairing process.
Congratulations. You can now control the deadbolt through the MiOS app and get notifications by using Meshbots on your smartphone whenever someone opens your Schlage deadbolt.
Comments
0 comments
