How to Pair Jasco Plug-in Smart Switch ZW4104
Sara
Sara
  • Updated
This guide will walk you through how to pair the Jasco Plug-in Smart Switch ZW4104 with the Ezlo hub.
  • Step 1: First, plug the device into a wall outlet.
  • Step 2: On the MiOS app, go to More > Devices.
  • Step 3: Tap the “+” symbol and select the controller where you want to add the device.
  • Step 4: Find the "Generic Z-Wave device" option and activate the pairing wizard.
  • Step 5: When the device is ready, tap “Next”, and the pairing process will start.
  • Step 6: When prompted, press and release the button on the device, then wait for it to be discovered by your controller.
  • The controller then pairs up with the sensor.
  • On the MiOS app, name your Jasco Plug-in Smart Switch ZW4104 and select a room to finalize the process.
You did it!
Congratulations.
Now, you can plug appliances into your Jasco Plug-in Smart Switch ZW4104 and remotely control it with the MiOS app.
Done! That's all there is to it. Now you can create Meshbots, and if for any reason you want to unpair, use the trash can icon on the upper right side of the screen in the Devices menu. follow the steps and confirm the unpairing.
Was this article helpful?
0 out of 3 found this helpful
Comments
0 comments
