How to Pair Zooz Motion Sensor ZSE18
Sara
Sara
  • Updated
Ezlo hubs are compatible with the Zooz Motion Sensor ZSE18. It’s simple to set up. Before you begin, have the sensor close to the controller.
  • First, open the cover of your Motion sensor to reveal the included battery and the inclusion button.
  • On the MiOS app, go to More > Devices, tap the “+” symbol, select the controller where you want to add the device, then go to "Sensors" and look for the "Zooz Motion Sensor ZSE18".
  • Tap on “Next” to commence the pairing process. Back to the motion sensor, press and hold the inclusion button on your Zooz Motion Sensor ZSE18 until it’s in pairing mode.
  • On the MiOS app, choose the name for Zooz Motion Sensor ZSE18 and give it room to finalize the process.
Congratulations.
Your motion sensor is now working and you can now set Meshbots.
If you want to remove the Sensor from your hub, use the trash can icon on the upper right side of the screen in the Devices menu, follow the same steps, and confirm unpairing.
Was this article helpful?
1 out of 2 found this helpful
Comments
0 comments
