Pairing your Aeotec Door Window Sensor 5 with your Ezlo Atom is a quick and easy DIY process if you can follow the below steps. So have your sensor’s user manual close by for details and continue reading on.
- Step 1: To begin with, place the sensor and the controller near each other.
- Step 2: Remove the plastic backplate of your sensor and clear the plastic tabs on the battery.
- Step 3: On the MiOS app, go to More > Devices
- Step 4: While in “Devices,” tap the “+” symbol, and go to “Sensors”.
- Step 5: Look for Aeotec Door Window Sensor ZW120 and select it.
- Step 6: When ready, tap “Next” for the pairing process to commence.
- Going back to the Door Window Sensor, press once on the action button, and the onboard LED blinks red for two seconds before turning solid to confirm the pairing.
- The controller recognizes the device and pairs it with your system.
- Back to the MiOS app, name your sensor, and give it room to finalize the process.
You can now use your MiOS app to create Meshbots and monitor the sensor.
Comments
0 comments
