How to Set Up Aeotec TriSensor ZWA005-A
Sara
Sara
  • Updated
Pairing
The Aeotec TriSensor is a Z-Wave Plus motion sensor that can double as a temperature and light sensor. This guide helps you through setting up your TriSensor with your Ezlo hub.
You can set up your Aeotec TriSensor with Ezlo Controller.
Here’s how to get started:
  • Step 1: Open first the backplates and connect the battery.
  • Step 2: On the MiOS app, go to More > Devices, tap the “+” symbol, select the controller where you want to add the device, then go to "Sensors".
  • Step 3: Find the Aeotec TriSensor ZWA005-A
  • Step 4: Select it and when ready, click “Next” to start the process.
  • Step 5: Going back to TriSensor, press the Action button on your sensor. The LED will blink as a confirmation of pairing.
  • Step 6: Check that your device pairs successfully. Once it recognizes the device, the controller will pair it with the system.
  • Step 7: Back to the Ezlo hub, wind up by choosing a name for your sensor and selecting a room.
  • Step 8: Once done, you can monitor the sensor from your MiOS app and use it to create Meshbots.
Congratulations!
Was this article helpful?
0 out of 0 found this helpful
Comments
0 comments
