The Dome Leak Sensor is a battery-powered sensor that detects water leaks and sends alerts to your hub. You can use it anywhere water leaks pose a risk, such as under the kitchen sink, laundry room, or near sump pumps. It is compatible with all Ezlo hubs.
Pairing
Pairing your Dome Z-Wave Plus Leak Sensor DMWS1 with Ezlo hubs is simple. Follow these steps:
- Step 1: First, unpack your leak sensor. Open the back cover. Next, remove the battery blocker. Before starting the pairing process, ensure your Dome Z-Wave Plus Leak Sensor DMWS1 is within range of the hub.
- Step 2: On the MiOS app, go to More > Devices, tap the “+” symbol, select the controller where you want to add the device, then go to “Sensors”, and look for the Dome Leak Sensor DMWS1. Select “Dome Leak Sensor DMWS1” to start the pairing process. When ready, click “Next” to commence the pairing process.
- Step 3: Go back to the sensor, and click the tamper button inside the casing three times in quick succession while holding the controller near the sensor. The controller will recognize the device and pair it with your system.
- Step 4: If everything was successful, your device should now appear under Unassigned devices. Click Done in your controller app to complete the setup.
- Step 5: That done, congratulations. Now you can start monitoring the water leaks from your Ezlo Hub.
Testing
To test the sensor, press the Test Button on the sensor. The sensor should beep and display a flash to indicate a test is in progress. Immerse the sensor in a cup of water, and it will flash red, showing leaks. Congratulations, your sensor works with Ezlo.
If you want to remove the Dome Leak Sensor from your hub, use the trash can icon on the upper right side of the screen in the Devices menu.
Comments
0 comments
