The ‘Customization’ area lets you change the look and feel of the EZLogic interface. You may want to simplify the UI so you only see the items you use most often and the information you find most valuable. You can also change the logo shown at the top-left of the interface to match your personal tastes or for corporate branding.
- Click ‘Settings’ > ‘Customization’ to get started:
The customization area lets you change the following items:
- Main menu – Choose which items are shown and which are hidden. You can also rename the ‘Automation’ section if required.
- MiOS Logo – Replace the ‘MiOS’ logo at top-left with your own logo.
- Meshbot listing page – Change the name of the page and select which columns are shown on the page.
- Meshbot Trigger UI – Change which items are shown in the ‘Node Type’ menu. Changes you make here only apply to Cloud, Notification and Interaction Flow meshbots. They do not apply to Local meshbots.
- Meshbot Action UI – Change which items are shown in the ‘Controllable Type’ menu. Changes you make here apply only to Cloud meshbots. They do not apply to any other type of meshbot.
You can undo any changes you have made by clicking the reset button in the lower-right corner:
Notes
- Any customizations you make only apply to the currently logged-in user. Other users on your account will continue to see the standard user-interface when they login.
- The customization menu item is only available and visible to account admins. It is not visible to advanced users, basic users or notification-only recipients.
- We hope to implement account-wide customizations and more user-specific options in future updates.
Please use the following links for help with each section of the customization area:
Menu
The ‘Menu’ area lets you modify which items are shown in the left-hand menu and to replace the ‘MiOS’ logo image with a logo of your own. You can also rename the ‘Automation’ section if required.
- Use the checkboxes on the left to hide any items you do not want to see in the menu.
- The ‘Preview’ panel on the right lets you view your new menu in real-time.
- Changes are not applied to the interface until you click the ‘Save’ button.
- The following example shows how the menu would look if you renamed ‘Automation’ as ‘Scenes and Scripting’ and chose to hide ‘Lua Scripts’, ‘NuCAL’ and the ‘Virtual Container’:
Upload Logo
The ‘Upload Logo’ button lets you change the image shown at the top-left of the interface. You may want to use this feature to promote your company brand or simply to change the look of the interface.
- Click ‘Settings’ > ‘Customization’ > ‘Menu’.
- Click ‘Upload Logo’
- Select the image you want to use. EZLogic will auto-resize the image you upload to fit the interface.
- Check the preview to confirm the image is to your liking.
- Click ‘Save’ to deploy the logo to the EZLogic interface:
- Your new logo is shown at the top-left corner of the interface and above the navigation menu:
Notes:
- Logo changes only apply to the currently logged-in user. Other users on your account will continue to see the ‘MiOS’ logo when they login. We hope to implement account-wide logos and more nuanced customization options in future updates.
- Custom logos appear at the top-left of the interface but, for now, the MiOS logo still appears on the dynamic dashboard. Again, we aim to improve on this in future updates.
Listing UI
The ‘Listing UI’ area lets you choose which columns are shown on the meshbot list page at ‘Automation’ > ‘Meshbots’. This lets you simplify the amount of data you see on the page so you only see what is important to you. You can also rename the page if required:
- Note. Ignore the meshbot names and other table data in the ‘Listing UI’ customization screen. It is just dummy data that allows you to preview how your changes will look. It is not a list of the actual meshbots you have created.
You can view any changes you save in the meshbot list page at ‘Automation’ > ‘Meshbots’
Meshbot UI
The ‘Meshbot UI’ area lets you modify the items you see in the drop-down menus when creating meshbot triggers and actions.
For example, you can hide ‘NuCAL’ and ‘Cloud Variables’ from your trigger ‘Node Type’ menu if you have no need for those items:
Click ‘Save’ to apply your changes.
- Triggers – Change which items are shown in the ‘Node Type’ menu of Cloud, Notification and Interaction Flow meshbots. Changes you make here do not apply to local meshbots.
- Actions – Change which items are shown in the ‘Controllable Type’ menu of Cloud meshbots. Changes you make here only apply to Cloud meshbots and not to any other type.
In the example above, we deselected ‘NuCAL’ and ‘Cloud Variables’ from the trigger section, leaving only ‘Device’ and ‘Date / Time’. We can see that change reflected when we go to create a new cloud meshbot:
Comments
0 comments
