Ezlo Protect v1.1
Sara
Sara
New Features
CMSN Professional Monitoring Integration
Cloud 1.110
  • Implemented flow for CMSN integration
  • Re-designed sign-up process with new password management flow
  • Device notifications & system templates
  • Notifications are now generated for activating or deactivating CMS test mode
Partner Portal 2.3.1
  • Fixed a permissions issue for creating new users
  • Implemented Default Pin Code for arming/disarming
Resident Portal 1.64.1
  • Signing-up from mobile now leads you to the correct mobile app
  • New device icons have been added
  • Implemented German language
  • Fixed issue causing the user to be automatically redirected to Controller Selection
  • Fixed issue with “Unknown Method” error appearing randomly
  • Fixed crash when accessing the Controllers settings tab
  • Fixed issue with cloud meshbot not displaying device capabilities
  • Fixed issue with meshbots not displaying their running state
  • General meshbots improvements
  • Added additional device types to create virtual devices
iOS Installer App 1.12(6)
  • Added Device Pairing Wizards for generic 345MHz devices
  • Entry delay duration is now configurable
  • Fixed issue for name validation when setting up Professional Monitoring
  • Fixed issue with keyboard staying open in the Device Pairing Wizard on swipe down
  • Fixed design issue, making the text easier to read on "Choose Your Controller" screen
  • Fixed issue with Network settings menu being hidden
  • Fixed issue with Doorbell camera not scaling to full screen
iOS Resident App 1.12(5)
  • Corrected permissions issue with “Basic user”
Android Installer App 1.118.0.2
  • The Settings screen has been reorganized for a more streamlined experience
  • Fixed issue with the app not displaying the paired devices in some cases
  • Fixed issue with Security Settings not fully loading
  • Fixed issue with erroneous “Controller offline” message
  • Fixed display issue with sensor triggers appearing as selected when creating a Meshbot
Android Resident App 1.118.0.3
  • Implemented Kiosk mode for the tablet version of the app
  • Fixed issue with the app not allowing to access the System Pin Codes
Touchscreen Dynamic Dashboard 2.1.27
  • Fixed issue causing the user to be automatically redirected to Controller Selection screen after a random amount of time
  • Fixed condition preventing the user to disarm the system from the Dashboard
  • Fixed issue with the list of camera snapshots/recordings not being fully populated
  • Fixed issue with cloud meshbots not being displayed on the Dashboard
  • Fixed issue with alarm countdown timer
  • Fixed issue with the House modes not switching
  • Fixed issue with Camera Streaming not being displayed
  • Fixed condition causing the thermostat widget to be unresponsive
  • Fixed issue with the Tablet chime not turning Off
  • Fixed issue with the weather forecast displaying incorrect values
  • Fixed issue with Arm/Disarm buttons appearing to be infinitely loading when hub was offline
  • Fixed condition preventing a device to be deleted from the Dashboard
  • Fixed condition preventing the user from manually run Meshbots
Firmware 2.0.38.2193.2
  • Added CO sensor to Device Generator plugin
  • Enabled hardwire input for 2GIG-DW10-345
  • Implemented Tilt sensor for Aeotec Door/Window Sensor 7
  • Improved functionality for Zooz Zen16 Multirelay
  • General bug fixes and improvements
Was this article helpful?
0 out of 0 found this helpful
Comments
0 comments
